some problem with simtools 2.0
Discussion in 'SimTools DIY Version' started by welen123, Jan 11, 2017.
  1. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    i had activate license for a professional license today,and here are some problem when i use it,maybe some guys have the same problem ,especially in Asia.
    My location is HongKong China,OS:Win10 and language is Chinese simplified.
    1. the same problem like the previous version 1.3,the UI user interface is still dislocation,like this:
    2.when I test the LFS,and data in the Tuning Center is still chaos,and if i turn on the virtual Axis ,the game Engine will crashed in 2 seconds.[​IMG] ,and i translate it in english by google,it means:
    Code:
    "The untreated anomalies in the application.If you click the "continue", the application will ignore this error and attempt to continue.If you click "exit", the application immediately shut down.
    Arithmetic operation led to a spill
    ******************Abnormal text*************
    System.OverflowException: Arithmetic operation led to a spill
       in SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
       in System.Windows.Forms.Timer.OnTick(EventArgs e)
       in System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** The loaded assemblies **************
    mscorlib
        The assembly version:4.0.0.0
        Win32 version:4.6.1086.0 built by: NETFXREL4STAGE
        Base code:file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    SimTools_GameEngine
        The assembly version:0.2.0.0
        Win32 version:0.2.0.0
        Base code:file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    zHdhcdiBgNoEFyBvjSWGKkhAoKyf
        The assembly version:0.0.0.0
    Microsoft.VisualBasic
        The assembly version:10.0.0.0
        Win32 version:14.6.1038.0 built by: NETFXREL2
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32 version:4.6.1081.0 built by: NETFXREL3STAGE
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        Win32 version:4.6.1084.0 built by: NETFXREL3STAGE
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        Win32 version:4.6.1038.0 built by: NETFXREL2
       Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        Win32 version:4.6.1078.0 built by: NETFXREL3STAGE
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        Win32 version:4.6.1064.2 built by: NETFXREL3STAGE
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Management
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Interface_PluginAPI
        The assembly version:1.0.0.0
        Win32 version:1.0.0.0
        Base Code:file:///C:/Program%20Files%20(x86)/SimTools/Interface_PluginAPI.DLL
    JRK_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/JRK_InterfacePlugin.dll
    Jrk
        The assembly version:1.1.0.1
        Win32 version:1.1.0.1
        Base Code:file:///C:/Program%20Files%20(x86)/SimTools/Jrk.DLL
    UsbWrapper
        The assembly version:1.5.1.0
        Win32 version:1.5.1
        Base Code:file:///C:/Program%20Files%20(x86)/SimTools/UsbWrapper.DLL
    MemoryMap_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/MemoryMap_InterfacePlugin.dll
    Network_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/Network_InterfacePlugin.dll
    SCN_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/SCN_InterfacePlugin.dll
    Serial_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/Serial_InterfacePlugin.dll
    AxisAssignments_PluginAPI
        Base Code:file:///C:/Program%20Files%20(x86)/SimTools/AxisAssignments_PluginAPI.DLL
    Generic2DBasic_AxisAssignmentsPlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DBasic_AxisAssignmentsPlugin.dll
    Generic2DStandard_AxisAssignmentsPlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DStandard_AxisAssignmentsPlugin.dll
    Microsoft.GeneratedCode
    Default_InterfacePlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/InterfacePlugins/Default_InterfacePlugin.dll
    Default_AxisAssignmentsPlugin
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Default_AxisAssignmentsPlugin.dll
    Game_PluginAPI
        Base Code:file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    LiveForSpeed_GamePlugin
        assembly version:2.0.0.0
        Win32 version:2.0.0.0
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    pCARS_GamePlugin
        assembly version:2.0.1.0
        Win32 version:2.0.1.0
        Base Code:file:///C:/Users/Administrator/AppData/Local/SimTools/GamePlugins/pCARS_GamePlugin.dll
    mscorlib.resources
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/mscorlib.resources.dll
    Accessibility
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Windows.Forms.resources
        Base Code:file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/System.Windows.Forms.resources.dll
    maybe the crash information can help the developer .
    3.i set the interface setting same like the previous version with SMC3 , and i have set the Axis Assignments
    but when i click the turn on button in the Output Testing , there is nothing happened with my simulation when i drag the bar. in simtools 1.3 it works,but not work here.
    the 3rd problem maybe the setting problem ,but i don't know where can find the user manual with simtools 2.0,maybe it not finished .
    my simulation can't run because of these problems ,so i can't test the other functions.
    really looking forward to these problems are solved.
    154,580Coins
    +11,190 / 57 / -2
  3. welen123
    HongKong
    35Coins
    thank you ,i changed the interface-Output:[A<Axis1a>][B<Axis2a>][C<Axis3a>],and now it works! you give me a lot of help!
  4. Kimy1989
    Kimy1989 Kimy
    463Coins
    2DOF, SCN5
    UI问题好像只有在XP系统里才会正常,LFS数据混乱和你的系统语言有关,你换成英文系统就行了。
  5. welen123
    HongKong
    35Coins
    我用的是WIN10系统,我知道改系统语言可以解决问题,但是希望开发者能够彻底解决这个问题,尤其是商业版的。
    in English:I use the WIN10 system, I know that the system can change the language to solve the problem, but I hope developers can completely solve this problem, especially the commercial version.
    154,580Coins
    +11,190 / 57 / -2
    Google Translate - UI problem seems to be only in the XP system will be normal, LFS data chaos and your system language, you replace the English system on the line.
    Google Translate - I use the WIN10 system, I know that the system can change the language to solve the problem, but I hope developers can completely solve this problem, especially the commercial version.
    Please include a Google Translation on the main threads.
  7. yobuddy
    51,676Coins
    Hi @welen123,
    I believe this is just an option I forgot to check in the plugin itself.
    Could you show me where else the gui messes up like that?
    thx buddy
  8. yobuddy
    51,676Coins
    @welen123
    Please drop this into the SimTools Plugin Updater.
    Then re-launch Game Engine and check to see if the gui is fixed.
    Let me know buddy?
  9. welen123
    HongKong
    35Coins
    @yobuddy
    Hi! buddy! i drop the interfacePlugin to the Plugin Updater and re-launch the Game Engine ,the GUI in the interface setting is still like above [​IMG]
    and i checked the Engine and Manger ,it looks like the GUI messes is only happened in the "interface Settings".
    and i had check to using the software"local emulator",it looks can work in WIN10 to fix the data problem ,so maybe this information can help you to find the problem of the data problem
  10. welen123
    HongKong
    35Coins
    thank you ,i will do that if i post the other language.
  11. obobo
    obobo Active Member
    1,323Coins
    it's not a problem with the truetype police ?
  12. yobuddy
    51,676Coins
    @welen123
    Let me know buddy?
  13. welen123
    HongKong
    35Coins
    @yobuddy
    Thank you buddy! it works!the GUI is fixed! it is excellent!thank you so much!hug:hug:hug:
  14. yobuddy
    51,676Coins
    @welen123,
    Thanks for taking the time to test it buddy!
    • Friendly Friendly x 2
  15. EL mansouri
    EL mansouri New Member
    - 49Coins
  16. noorbeast
    154,580Coins
    +11,190 / 57 / -2
    The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
  17. EL mansouri
    - 49Coins
