Some issues to work out
Discussion in 'DIY Motion Simulator Projects' started by estami, Sep 22, 2019.
  1. estami
    estami New Member
    Industrial maintenance
    Alcañiz Spain
    95Coins
    Hello, I have tried it with other sketches and other programs, not with this one that is on this page and it worked well ... but now I am going to do it with this one and I have been recommended to use this:
    https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    As I am using motomoster shield, the sketch to use would be mode 1 and the wiring as indicated in that post ..... I have done some test and it still does not move.
    At the moment I have to install licensed simtools and get the plugins to see if I get the necessary coins since my economy is not very good jjjj
    I will keep trying to see if I get it, I will tell you the result.
    By the way I don't know if it will be understood well I am using a translator
    Greetings
    154,238Coins
    +11,176 / 57 / -2
    Please post pictures of all of your settings and wiring.
    If you are using cheap clone MMs make sure you test them, as many are faulty: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    The demo version of SimTools comes with the fully functional plugin for SimTools, specifically for the purpose of testing.
    Conditions apply and when met eligible DIY builders can apply for a free DIY SimTools license:
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the testing phase.)
    • Have been a member of the community for at least 30 days.
