SMC3 Code and SMCUtils Question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by firstinflight, Jul 1, 2019.
  1. firstinflight
    firstinflight Member
    USA
    174Coins
    Hello.
    I recently expanded my 2DOF project from RC servos to a couple of actuators. I purchased a Progressive Automation linear actuator with builtin feedback and a MultiMoto shield for my Arduino.
    I was able to plug the MultiMoto card into the Arduino and get my actuator work. However that does not leave me any ability to plug in the position feedback from the actuator.
    More importantly, I installed the SMC3 code and uploaded it and got nothing. SMC Utils would connect to the Arduino but would do nothing,
    I then connected the Arduino and MultiMoto card seperately wondering if that was the issue and made all the necessary connections. Once again, SMC3 code did nothing and nor did Utils work.
    Need your help to figure out what I am missing. I followed all the steps in the tutorial and have now checked and re-checked several times. I am using MODE1 because its a simple PWM card with two inputs for direction.
    Thanks in advance,
    CJ
    154,400Coins
    +11,181 / 57 / -2
    Can you please post a link to the actual actuator product page, so we know its specs and how it is controlled.
  3. firstinflight
    USA
    174Coins
    Here is the link to the actuator product’s page.
    https://www.progressiveautomations.com/products/linear-actuator-with-potentiometer
    Here is the link to MultiMoto Shield.
    https://www.progressiveautomations.com/search?type=product&q=Multimoto
    Here is a link to sample code.
    https://www.progressiveautomations.com/pages/resources#arduino-coding
    Thanks for the reply.
    CJ
  4. BlazinH
    16,698Coins
    SMC3 requires position feedback to work.
  5. firstinflight
    USA
    174Coins
    That’s correct. That’s my understanding from reviewing the SMC3 code. That’s why I purchased an actuator with feedback built in.
    Upon testing it with my test code, the feedback works well.
  6. firstinflight
    USA
    174Coins
    I should also add that I un-stacked the Shield yesterday. Connected it with connectors and that opened up all of my Arduino pins for me.
    Works fine now. Feedback is connected to A0.
