Question Simtools crashing USB device
Discussion in 'SimTools Pro & Entertainment Version' started by Rodrigo Baornio, Jan 15, 2022.
  1. Rodrigo Baornio
    Rodrigo Baornio New Member
    Brazil
    - 285Coins
    i sell in brazil servo actuadores with simtool pro to the guy use in his home.
    simtools works for hours, but it crashes my usb device, sometimes when I leave and enter the game again, or in the test when I turn off, and turn on again, it stops working, I end up having to close the 2 simtools, take it out and put the usb and open the simtools again, the curious thing is that sometimes when I do this it stops working, but sometimes I manage to turn on/off 2a3 times until it stops working, but in the game when it is working, there is no problem, only when you leave the game and will enter again, or some cases like asseto Corsa, if you try to change cars. does anyone know what could be happening? O try simtools 2.4, 2.51... um using simtools since 1.3 qnd Its happing more now
    photo of serial interface
    https://drive.google.com/file/d/1mDQKaFFWbm_3kunNS2r-_2c83aKKpLiY/view?usp=sharing
  2. yobuddy
    50,334Coins
    How long is your usb cable, or are you using a usb hub?
    That would be my first guess anyway.
    Take care,
  3. Rodrigo Baornio
    Brazil
    - 285Coins
    O go back and use teensy and its working with no problem, some times o have problem with cable, and now using good cables, but now, my New board with stm32 os doing It, i Will check again change the serial comunication program
  4. Rodrigo Baornio
    Brazil
    - 285Coins
    it was really a problem with a port locking with my new device stm32 with firmware update, it was considering a firmware update and when it turned OFF on simtools, it was waiting for other commands, so I was able to solve it in my programming. thanks
