Question Simtools crashes ?
Discussion in 'SimTools Pro & Entertainment Version' started by Gadget999, Jul 28, 2022.
  1. Gadget999
    11,947Coins
    The last few days simtools has become unstable
    I have been using simtools with RF2
    At random I can hear a windows sound alert and the motion stops working.
    When you look at the processes the game manager and game engine are active
    When you close rf2 the game engine dissapears
    Restart simtools and the motion comes back
    Any suggestions ?
  2. yobuddy
    50,334Coins
    Check the interface cables.
    Sounds like an interface is dropping out.
    Take care!
  3. Gadget999
    11,947Coins
    Yes it sounds like a usb decice has dropped out
    My main sim uses 3 boards running smc3
    When i checked the com ports they are all there.
    Reopening simtools and everything is ok again
    I have stopped simtools opening when windows does to give everything time to tie its laces - lets see if anything changes
    150,686Coins
    +11,018 / 55 / -2
    Even a micro disconnect can mess with SimTools.
    You can map what USB devices are mapped to which controllers, as it is easy to overload a USB controller, see the FAQs here: https://www.xsimulator.net/community/faq/usb-disconnects.396/
    Ferrite magnet clips on cords can help minimise interference, which can be an alternate possibility.
  5. Gadget999
    11,947Coins
    Some good information there
    Whats interesting is the sim has been good as gold for a long time, this is a new problem
    The only change I can think is an update to RF2 and also windows
    I will start with ferrite chokes and after that a pci usb card
    Thanks for the help :)
  6. yobuddy
    50,334Coins
    May be worth trying to plug stuff into usb 2.0 ports (if available) and see if you get the same result.
  7. Gadget999
    11,947Coins
    I think my usb ports are 2.0
    I have added chokes on both ends of the 3x usb cables - so far all good ❤️
