Question SimTool tuning center and Profile edit questions
Discussion in 'SimTools Pro & Entertainment Version' started by joe extraknow, May 27, 2019.
  1. joe extraknow
    joe extraknow Member Gold Contributor
    United States
    1,550Coins
    hi questions I have:
    1) In Game Engine, the Tuning center:
    I can save a set of min/max settings per Game. Is any way that I can save them per Car within a game?
    2) I would guess the answer above is No, so I have to go Game Manager, at Profile Editor:
    At Main, I can adjust main level then save it per Car. It seems work.
    But at Editor, I try to adjust roll/pitch/surge/sway respectively,I found no affect at all. Is a bug here? Shall I upgrade to latest SimTool?
    Also, when I slide to left or right on roll/pitch/surge/sway, what does actually mean? Since the min/max setting is already fixed, do I just adjust the smooth factors in this case? Say 100% means “zero smooth effect” and 0% means “100% smooth effect”?
    153,053Coins
    +11,117 / 56 / -2
    As you expected you can make a generic profile for the game, then in Game Manager in the Profile Editor -> Editor you you can create variations of it for individual cars and/or tracks.
    The Game Manager Profile is basically changing the TC Max/Min values, see the explanation here: https://www.xsimulator.net/communit...ave-normally-assetto-corsa.11999/#post-156499
    It is hard to give any specific advice until you post pictures of all of your settings, as the base profile has to be well refined before any Game Manager profiles are created: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  3. joe extraknow
    United States
    1,550Coins
  4. yobuddy
    51,378Coins
    @joe extraknow,
    1 ) When 2.4 drops, this will be an option in Game Engine. (separate Min/Max per Game Manger profile)
    2) You are actually adjusting you Min Max values by up to 50% smaller or larger.
    Take care!
  5. joe extraknow
    United States
    1,550Coins
    I wish I could alter the settings beyond the +/-50%. In rF2, motion feels between the ISI native GT cars and open wheelers seems to me bigger than 50%, though.
    thanks
