Sim commotion using Arduino Mega and X-sim software
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pixel, Aug 19, 2010.
  1. Pixel
    Pixel New Member
    1Coins
    Hello and registered exclusively to realize my project of cockpit, the plate wanted to use His Arduino Mega and a bridge in H to control the Simcon motion and if the ventilator sensitive to the speed can.
    I wanted to be able connect like the bridge in H to the plate Arduino Mega or algun information or reference of a bridge in H commercial me interesaria mas since the process is not given me well of made of PCBs.
    If tubiera that DIY to make the bridge in H me gustaria that were saying to me like Arduino Mega to connect it to the plate.
    Pardon for the Englishman a translator uses since Englishman does not speak himself.
    Regards and thanks.
  2. Ads Master
    Ads Master
  3. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    582Coins
    I think this needs a better translation.
    Witch translator are you using.
  4. Pixel
    Pixel New Member
    1Coins
    Hello i am registered exclusively to realize my project of cockpit, wanted to use Arduino Mega and a bridge in H to control the Simcon motion and if the ventilator sensitive to the speed if you can clear.
    I wanted connect the H bridge to plate Arduino Mega,or other infomation ther other H bridge commercial as reference, model...
    But i am interesting in h bridge commercial.
    In case do the Diy H bridge , i am not know conect to ther Arduino Mega.
    Sorry for my english, i use ther translate google.
    Regards and thanks.
  5. wimpo`
    wimpo` Member
    metselaar
    582Coins
    Still not sure about what you mean, is it that you want to build a frex like simulator.
    or do you want to have ventilators to simulate wind.
    And what country are you from, maybe there is someone from the same country on this forum.
  6. Pixel
    Pixel New Member
    1Coins
    I would like to replace it by Arduino Mega these pcbs:
    [​IMG] [​IMG]
    And the question is how to connect the H bridge has the Arduino Mega, and how to configure the x-simulator software for the Arduino Mega.
    Regards and thanks.
  7. tronicgr
    tronicgr
    One of these days that will have more free time will re-write the motion control algorithm I use for AMC1.5 in C and port it to Arduino Mega. It just needs much experimenting and fine tunning of the code until is stable and fast for our purposes.
    Thanos
  8. sterex
    sterex New Member
    hello Pixel.
    I don't think that you can replace the whole thing with arduino. Even if you managed to get the arduino working, (which it will, with some codes), you will still need the H-bridge to drive the motors.
    Basically you just have to figure out how to read the incoming data from x-sim and then signal the H-bridge in theory. I know its easy to say so then to do. Maybe you might bump into some problems early but thats life.
    I am working on a similar project with arduino. I had some success reading the data from x-sim and running a wiper motor with it. But haven't had enough time lately to write the whole code yet. If you are willing and good at programming you can manage to write a whole PID control interface for x-sim with arduino mega. Ofcourse there are all types of 'itsy bitsy stuff' in the whole equation of an interface. but only you can choose the aspects of the interface according to your need.
  9. egoexpress
    331Coins
    That would be great, Thanos :cheers:
    Do you think the Arduino is fast enough to handle full PID and quadrature encoders?
    Regards
    Christian
  10. wimpo`
    wimpo` Member
    metselaar
    582Coins
    why not just write it in assembly, there are lots of tutorials for it
  11. Pixel
    Pixel New Member
    1Coins
    I want to connect the H bridge DIY in Arduino Mega.
    like conect the Red circle to Arduino Mega?
    Uploaded with ImageShack.us
    And what is not is how.
    Greetings and thanks
  12. wimpo`
    wimpo` Member
    metselaar
    582Coins
    it will work I think because of the TTL signals.
    But you will have to find out the functions of the pins on the h-bridge.
    as I recall this h-bridge uses 2 direction pins for 1 motor.
    0-0 no current
    1-0 left
    0-1 right
    1-1 brake
    but thanos or frakk would have to confirm this, because I'm not sure.
  13. juniou
    juniou New Member
    Brazil
    231Coins
    Hi Pixel,
    Check this post. post30952.html#p30952
    Maybe help you with some idea.
