Question SFX-100 Builders in Australia
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by ThumpMan, Apr 28, 2020.
  1. ThumpMan
    ThumpMan New Member Gold Contributor
    Australia
    95Coins
    2DOF, SCN5
    Hi All,
    I have been an active member for years and lost all my info as its been some time since jumping back onto the sim forums. Hence seems I am new again.
    I have been running a SCN5 (frex) seat mover for years and just decided to upgrade to a new rig. I went the Trakracer TR80 route as I have been using extrusion for years and its good look and fit for my space.
    As I pour over the hundreds / thousands of threads and posts obviously the SFX-100 has caught my eye especially as I run VR. The initial thought was to convert my 2dof to 4dof.
    I actually already brought the extrusion only to start pouring over the threads again and be excited by the progression within this community. So I have a new rig on the way, more extrusion than I need and want to build a sfx-100 sim.
    So I am based in Sydney and looking for other SFX100 builders in Australia to give me a hand with my new build. I will sell off the SCN5 seat mover and want to start this SFX100 build.
    My greatest constraint is time. I have an extremely busy job so time is one thing I dont have a lot of.
    So I am putting the call out to my fellow aussies for some help and support as I venture down this path.
    WAF would definitely increase if my simulator chirps nearly disappear
    I do hope the my fellow locked down aussies can provide assistance
  2. David Desira
    David Desira Rat Racing
    Instrument tech
    Melbourne Australia
    86Coins
    Hi Thumpman, I'm new here as well & thought I'd say hi. I'm also looking at a total upgrade of my old rig, making a new setup complete with the sfx100 actuators. Have you made a start on your build?
    Currently putting a list together to order all the parts this week
  3. ThumpMan
    Australia
    95Coins
    2DOF, SCN5
    Hi David
    Yes I have started my build. Lots to absorb. I am putting a list together of places I purchased the parts from in Aus.
    Note - I still purchased my extrusion from Germany and motors from china
    PM me if you want some assistance
  4. David Desira
    Instrument tech
    Melbourne Australia
    86Coins
    Thanks mate, I appreciate your help. You're not kidding about a lot to learn!
    My worry is more the computer side, engineering not so bad. it's good to have a local contact to share ideas and help. Cheers, David
  5. shanothegreat
    shanothegreat Member Gold Contributor
    Technician
    Melbourne, Australia
    496Coins
    2DOF, DC motor, JRK, SimforceGT
    Hi Dave, I have just finished ordering the parts for the actuators, motors from China on Saturday, just over AU$1,300 shipped. I sourced most of the parts, ball screws, bearings, etc through Aliexpress without much trouble except 30mm hollow bearing shaft which never arrived (refund given). Ironically the Item24 profile was available from a Melbourne supplier, AU$400 shipped, and the bearing shaft from another Melbourne supplier AU$170 pick up.
    I'm probably going to fashion a chassis myself out of aluminium, only as I have my own AC Tig welder and am going to go for a more rigid tube chassis, I have CAD drawings of a Formula Ford to follow.
    Good Luck and feel free to contact me if you need any info.
    Regards
    Shane
  6. Thanos
    Electronics Engineer
    United States
    2,862Coins
  7. Andrew Bird
    Andrew Bird New Member
    Christchurch, New Zealand
    205Coins
    3DOF, AC motor
    I'm just across the ditch in NZ so found it cheaper to get parts from Aliexpress as well, Kinetik was too expensive especially for the Extrusion. I did get a quote for the 100 x 100 extrusion from Item in Australia but the shipping made it too dear at $360 AUD (plus tax) for 4 x 250mm lengths. I then contacted a seller on Alibaba and was able to get 8 x 250mm cut lengths (making a set later for my uncle) delivered for $359 NZD including shipping which gets it down to $180 for the 4 I needed. Can share the seller info if you want it. Only thing is I picked the heavier extrusion that has 12mm holes for the threads so I had to order some M14-M8 thread reducers to fix that, can sell my M12-M8 inserts later.
    I was lucky that all my SFX-100 parts I ordered from Aliexpress actually arrived and most of it over the lockdown, deliveries since then have actually gotten worse with some things just not showing up at all.
