SFX-100 Actuator Homing & Calibrating
Discussion in 'Motor actuators and drivers' started by ERGUN OZYURT, Sep 7, 2020.
  1. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    Hi everybody,
    I am looking sfx-100 actuator design, but I can not find any limit switches etc for homing & calibrating. How sfx-100 find home position ? I know servos are intelligent but they need absolute positioning for range if they dont have absolute encoder ?
    Any knowledge ?
    Thanks.
  2. morpwr
    morpwr New Member Gold Contributor
    36Coins
    If you use the Thanos controller it has protection built in for that. He has videos showing how it works. Ive been using his for a few weeks now and it works great.
  3. Thanos
    Electronics Engineer
    United States
    2,917Coins
    Be careful with servomotor. If not using proper controller, you might face a few unexpected problems or failures down the road, that you should be prepared for. See here on this video where I force for the sake of documentation some common failures and how the protections kick in to prevent damage.
  4. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    Thanks for explanation. But I want to know how this technically can be done ? I am not talking about protection. You may get alarm from servo controller and stop simulator.
    But in normal conditions, while you are using your simulator, electric goes down. Controller and no body knows position of any actuator. After electric come again, how it can determine last positions of actuators ?
  5. wingert
    wingert Active Member
    738Coins
    4DOF
    the weight of the rig pushes the actuator with no motor power always to the lower starting position
  6. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    I did not tested it yet, but as I read about ball screws, there is a lock to for linear motion without spinning, like gearboxes. If there is a lock, rig should not move with weight. If there is no lock, holding torque of servos should be enough for holding rigs when no motion.
  7. Thanos
    United States
    2,917Coins
    In any case you need to calibrate the home position of the actuator EVERY time you enable the servo, even with worm gear. And with leadscrew you still may not 100 confident that all actuators are really lowered down to 0 position by gravity...
    You can even use external contactless limit switches if you don't want to try the motor against hard stop (if not available for example):
  8. wingert
    738Coins
    4DOF
    Not in this concept, e.g. if you push the E-stop the rig moves immediately down.
  9. Thanos
    United States
    2,917Coins
    Correct... The AMC-AASD15A controller however has hold mode e-stop as well... it will hold position of the motors even if not equipped with brakes ;)
    Have another look in the video:
