Server Psu + battery
Discussion in 'Electronic and hardware generally' started by Simon_lebel, Aug 18, 2015.
  1. Simon_lebel
    Simon_lebel Member
    Levis, Quebec
    157Coins
    2DOF, DC motor, JRK, 4DOF
    It may have been already covered but, I have two psu out of a server that shut down under stress. All i have to do is unplug and plug them back. Would it be a good choice to put a battery in parallel with the supply output? No need for a basic dc lesson, i'm a electrodynamics technician but still i don't know the answer... A charger is not only a supply, i think the voltage has to be a little bit higher than the battery, right? If you guys think it would work, how big does it have to be? I have some ups 12v battery maybe i could use them...
    Thanks hope somebody can help me
  2. Ville Pesonen
    Ville Pesonen Active Member
    831Coins
    I had the same problem as you have. I resolved it by adding 27000uF capacitor parallel to the psu. I think that a battery would work also but I have no idea of the size needed. Maybe a motorcycle/car battery would work.
  3. bsft
    yes, just unplug the PSU from the battery after use
  4. matthewdtwo
    matthewdtwo New Member
    287Coins
    Some large electrolytic capacitors would do the trick as well. The kind most often used in car audio would be a good choice, but any decently sized (>10,000uF) would help out a bit. If you do want to go the battery route, I'd recommend a blocking diode in series between the PSU and battery to keep it from feeding back in when the PSU is turned off. There is likely some internal protection, but diodes are cheaper than PSUs so I wouldn't risk it.
