Screens, projectors and graphics cards
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Mar 17, 2020.
  1. Gadget999
    12,072Coins
    i am trying to work out what is best to do for my 6dof
    i have a projector that could work
    or do i go for screens
    i like the fact the screens will be close by and will have a better resolution
    there are curved screens and lots of people use 3 screens
    Question 1. To use 3 screens do i need 3x graphics cards ? (RF2)
    Question 2. do i need the screens attached to the sim or static on the ground ?
    Question 3. are the curved screen(s) worth the extra cost ?
    p.s - I may explore a vr headset later on
  2. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    I have a 1080p projector and the rift s. The projector is pretty nice but I enjoy the rift more.
  3. Gadget999
    12,072Coins
    does it need to be dark to use the projector ?
  4. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    The darker the better the image will look, I use VR, current graphics cards have multiple outputs for multiple screens, if yours is modern you will have no problem putting multiple TVs
  5. Keith
    Keith Active Member
    Electrician
    154Coins
    Yes like Zapata said. The Darker the better.
    What graphics card do you have?
  6. Gadget999
    12,072Coins
    the graphic card is a geforce gtx 1050 Ti - can it run more than one screen ?
  7. Keith
    Keith Active Member
    Electrician
    154Coins
    With that graphics card you should stick to just one monitor. That card would also struggle with vr
  8. Gadget999
    12,072Coins
    looks like it will support 3x screens
    • New NVIDIA Pascal architecture delivers improved performance and power efficiency; 240Hz Max Refresh Rate
    • Classic and modern games at 1080p @ 60 FPS; Max Digital Resolution - 7680x4320
    • Fast, smooth, power-efficient gaming experiences; Max Monitors Supported: 3
    • Base Clock: 1354 MHz / Boost Clock: 1468 MHz; Memory Detail: 4096MB GDDR5
    • EVGA GTX 1050 Ti SC GAMING - Compact Size 5.7in; Max Monitors Supported: 3
    • NVIDIA G-SYNC Ready; OpenGL 4.5 Support; Simultaneous Multi-Projection & NVIDIA Ansel
    • NVIDIA GPU Boost 3.0; Microsoft DirectX 12 API; Vulkan API & PCI Express 3.0
    • HDMI 2.0b, DisplayPort 1.4 and Dual-Link DVI-D; Built for EVGA Precision XOC
    • Requirements: 300 Watt or greater power supply & Windows 10 32/64bit, Windows 8 32/64bit, Windows 7 32/64bit
    • Dimensions: Height: 4.376in - 111.15mm; Length: 5.7in - 144.78mm & Width: Dual Slot
  9. Gadget999
    12,072Coins
    so the vr headset is effectively a screen ! i thought it would have its own graphics processors
  10. Keith
    Keith Active Member
    Electrician
    154Coins
    Pretty much yes. Your 1050ti would be fine in triple screen and vr for some games. I am running a gtx970 which is faster than 1050ti. Assetto corsa runs good. Dirt rally runs just ok. Dirt rally 2 is unplayable. Im talking VR at 1440p resolution
  11. zapata_h
    España
    308Coins
    Indeed VR glasses behave like one more monitor, in fact it consumes many more resources than a monitor, with the graphic card that you comment it would be very fair for VR
