SCN5 150mm Reliability
Discussion in 'New users start here - FAQ' started by bvillersjr, Jan 14, 2010.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Hi sn4il,
    In a previous thread that was intended to help people avoid actuator damage, but resulted in an unfortunate competitor hi-jacking, you asked a very important question.
    The answer is, there are no known cases of SCN5 150mm actuator failure.
  2. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Thats good news for me, as i want to buy a pair from you in the near future. (oh and my rig was not fine...;))
  3. sn4il
    sn4il New Member
    2Coins
    In one of Your thread about broken pin some1 made statement that SCN5 depends only on motor bearings. Is the motor different between 100 and 150 actuators or its just a ball screw?
    bvillersjr
    I really appreciate what You are doing for the community and I'm looking forward to start with Your dimmensions listed in other thread.
    Personally I think these angles are critical expecially with heavier drivers like myself.
    I was going to use double SCN5's per side but it's more complicated than I thought.
    sn4il
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    Hi
    All scn5 are the same
    The screw is allsow guided by the nut.
    Longer strokes are slower because critical speed from screwshaft
    regards
  5. bvillersjr
    Ohio, USA
    438Coins
    I agree. The internals are the same, just a longer stroke. However, Dyadic claims that both 100mm and 150mm are capable of 400mm / sec. My guess is that they arer actually capable of slightly more than this at lower stroke lengths. In most implementation, less than 300 mm/sec is all that is achievable anyway due to the load.
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    Hi Bernard
    Youre right, there is a standard of 20% safety marge in industry.
    A 150mm is able to reach 480mm/sec before they start vibrate,and a 100mm can have more.
    But there is allso friction from nut and screw thats limiting the rpm.
    Regards
