Question Rock‘nRide Chair revive
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by ArneHappy, Jul 20, 2020.
  1. ArneHappy
    ArneHappy New Member
    75Coins
    Hi there,
    I own one of those old Rock’n Ride Chairs. Right now it is disassambled and I don‘t know if the board is ok.
    I was thinking of using the VM110 board and FSUIP on FSX. But I would need a jump start on what to aquire and what to connect where.
    Any ideas? Should I rather use an Arduino?
    Regards
    Arne
    151,100Coins
    +11,030 / 56 / -2
  3. ferslash
    ferslash Active Member
    4,798Coins
    arduino is super simple, you dont have to hack anything, construct from the ground up is a lot easier than "hack" what some one did.
    - try buing a chinese arduino clone and some motor drivers (also cheap)
    - buy a wiper motor (and old, dirty, used one on a junk yard)
    - connect all the pieces to simtools following the instructions on the forum
    you will learn a lot and then you can jump to easely modify your rocknride
    mounting the hole "model" stuf (the arduino, motor diver and motor and simtools) will take you 2 hours or less depending on your skills, then you will have a super clear view of what you need... trust me, it is super easy
    fer
  4. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    Hi Arne, I posted a chain solution for RnRchair from someone on YT. Maybe that might be good Inspiration for you. You find it in my showroom thread on page one. I hope that helps a little.
    BTW. you found a great helpful Community. Just ask - hier wirst Du geholfen.
