Rift arrived can't load pcars
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Boomslangnz, Jul 11, 2016.
  1. Boomslangnz
    4,172Coins
    My rift arrived today and set everything up on it and all seemed good. However when I try load pcars and select oculus mode. Nothing is coming up on my rift and it just loads the game on my projectors as per normal
    154,400Coins
    +11,181 / 57 / -2
    The Rift can be fussy about what display port it is plugged into, is it plugged directly into the hdmi port?
    If it is the Steam version of Pcars it should be launched as Oculus Rift in Other VR Mode:
  3. Blame73
    Blame73 Well-Known Member
    8,315Coins
    Have you enabled unknown sources in OR settings?
  4. Boomslangnz
    4,172Coins
    yes done all that, ive spent all night trying to get it going and I dont know whats causing it not too. Ive got rift connected directly to hdmi on my gtx 970 while both projectors are connected to dvi on the gtx 970. The oculus home menu and apps in that load fine on rift as does no limits rollercoasters from steam. Loaded perfectly fine on rift as does steam vr but no matter what i do to load pcars i just get some message saying sorry,pcars64.exe is taking too long to load etc etc and never loads. I even uninstalled pcars and reinstalled it and still does it
    I disabled my intergrated gpu etc just to make sure that wasnt doing anything funny, also had my oculus remote die on me basically. Keeps losing sync every 5 seconds or so and turns itself off. I replaced the battery just to make sure it wasnt that but it keeps doing it. I un-sync remote and then resync and it works for 5 seconds or so then turns off
    154,400Coins
    +11,181 / 57 / -2
    I would try it with just one projector plugged in.
  6. Boomslangnz
    4,172Coins
    i hear ya, but i shouldnt have too. I just tried out iracing, dirt rally and a few oculus demos and all of them ran perfectly fine with how im setup. Only project cars is having issues
    154,400Coins
    +11,181 / 57 / -2
    I get that, but Pcars does have known issues with the Rift and multi monitors.
  8. Boomslangnz
    4,172Coins
    yep turned off surround and unplugged each projector seperately and it still does not load up
    (tried running it between unplugging each)
    154,400Coins
    +11,181 / 57 / -2
    Did you reboot with just one projector plugged in?
  10. Boomslangnz
    4,172Coins
    yeah i did, still no go unfortunately
    154,400Coins
    +11,181 / 57 / -2
    I just want to clarify, your Rift works fine on everything except Pcars?
    What is the exact wording of the error you get?
    What version Nvidia drivers are you running?
    What are your in-game Pcar settings and have you tried winding them back?
  12. SilentChill
    20,603Coins
    Just dont play pCars as its crap :D Get Assetto Corsa instead :p
  13. Boomslangnz
    4,172Coins
    yes everything else works fine
    Sorry, Pcars64.exe is taking a while to load. If this issue persists, please take off your headset and check this app on your computer.
    running the latest drivers
    ive deleted the entire config file and tried and it still doesnt work, it creates new ones as default
  14. noorbeast
    154,400Coins
    +11,181 / 57 / -2
    I am pretty sure it is how things are plugged into the card. Can you try disconnecting the projectors and plug a monitor in the DVI port.
  15. Boomslangnz
    4,172Coins
    yeah tried that still didnt work.
    However i have had some progress, I renamed the pcars.exe to pcars64.exe to try the 32bit exe and it loaded onto oculus fine, first time ive managed to get it even showing on it.
    It just wont load the 64bit exe file on my windows 10 64bit
  16. noorbeast
    154,400Coins
    +11,181 / 57 / -2
    By any chance is Steam VR or Steam Theatre enabled?
    Are you launching it via Steam when you are playing around with the renamed exe?
  17. Boomslangnz
    4,172Coins
    nah mate they arent loaded but I have used steam vr before and yes i launch via steam
    Ive now just ordered a new ssd and going to do a fresh install of windows 10 tomorrow night, see what that does. I wanted to upgrade my ssd size anyway
  18. noorbeast
    154,400Coins
    +11,181 / 57 / -2
    A radical step but it may do the trick having everything clean installed, as it really should just work out of the box.
