Question about mode1/2
Discussion in 'DIY Motion Simulator Projects' started by piedjie, Aug 10, 2022.
  1. piedjie
    piedjie New Member
    79Coins
    I'm currently building my own motion sim based on a trak racer tr8 chassis. 2 wiper motors, hall sensors, land rover U-joint. So far so good.
    I'm struggling with smc3 though. I'm using an arduino and a motor controller from Akozon (DC-5). The motors do turn when the green line is in the middle. They stop after a half turn because the green line shifts under the red line. The pots are wel connected.
    Should I select mode 2 and use a second motor controller for this. I'm confused (and tired from the late nights trying)
    If I turn the pots with my hands I can make the motors change direction.
    150,974Coins
    +11,025 / 56 / -2
    I have no idea what your control board uses but: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    MODE1: HIs for boards that have a PWM output pin plus two Motor Direction output pins.
    MODE2: Designed for H-Bridges that require direct drive of Highside and Lowside switch inputs. In this mode one switch is driven as a direction pin and the other with the PWM output however the PWM duty needs to be inverted whenever the motor changes direction with the direction pin. (An alternate approach would be to switch the PWM between inputs as direction changes).
  3. piedjie
    piedjie New Member
    79Coins
    It has 2 outputs so I guess I should use mode1. Just strange the “green line” shift till the end so it stops the motor. The pots (hall) are reacting. Can I make them less or more sensible?
