Q : AQMH3615NS versus BTS7960
Discussion in 'Motor actuators and drivers' started by cx5my, May 17, 2022.
  1. cx5my
    cx5my Member Gold Contributor
    Loudspeaker Manufacturing
    Hong Kong
    251Coins
    Hi guys, I'm newbie, don't know motors and controllers, hence a lot of questions and curiousity, upon studying found AQMH3615NS seems like a good 36volts upgrade versus BTS7960 24volts.
    but AQMH3615NS max only 20amperes and requires massive cooling informed by seller = https://item.taobao.com/item.htm?spm=a1z0d.7625083.1998302264.6.5c5f4e69r9pV8i&id=555823724958
    Under 10amperes don't need extra cooling. A 6DOF scenario of 36v*10A=360watts each motor * 6 = 2160 watts to push HEAVE upwards a 100kg load, ..... should be enough right?
    Adds lot of cooling just incase and make sure PSU has lots of headroom too.......
    i.e. 500watts motor have 30% headroom also.... etc etc etc
    Apart from 3x more expensive than BTS7960, what other problems or incompatibility with SMC3+Arduino?
    Thanks.
    153,890Coins
    +11,154 / 57 / -2
    Hardware has to be able to talk to software, I don't recall anyone using a AQMH3615NS, so am not sure how it my go with the likes of SMC3.
  3. cx5my
    Hong Kong
    251Coins
    Hi @noorbeast,
    I think the AQMH3615NS has IN1 and IN2 are forward and reverse, then PWM as in ENABLE, seems to be able to take Arduino's signal just as a BTS7960. PWM shortest pulse width is 200ns = estimated 5khz
    funny it has a 5V_output instead of input.
    and below no part number motor controller also has same input pin connections, I think, at least to my inexperienced eyes seems they are completely interchangable with BTS7960.
    https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.102.ac847484jW5iqP&id=670587272460
    both are at least 3x more expensive than BTS7960 ......... sacrifices for higher voltages ......... not sure which is more important or directly useful to us, voltage? ampere?
    Voltage gives fast response, ampere carry heavy load..... or is not as simple as it seems???
