value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. value1
    14,305Coins
    Project CARS Plugin - SimTools game plugin for Project CARS
    • Like Like x 7
  2. value1
    14,305Coins
    That can well be. I'll have a look into V4.
    Thanks for the heads-up!
    Edit: There's indeed plenty of new information in V4 – less relevant for motion simulation but screaming for an updated plugin – the benefits of betatesting pCARS ;)
  3. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    Hi !
    It seems the plugin doesn't work anymore with the new V4 shared memory from PCARS.
    Anyone else can confirm ?
  4. Erwan960
    3,832Coins
    We have just to wait until the release of the new version of the plugin. The lack of movement significantly reduces the interest of the simulator !
    Thank you in advance to the people working on it !
  5. value1
    14,305Coins
  6. Erwan960
    3,832Coins
    I downloaded, installed and tested the last version of the plugin. The problem is it doesn't seems to work.
    I'm using SimTools 4.2
    - I checked "shared memory" is on in the game.
    - I reinstalled the plugin.
    - I checked the properties were the same as with the plugin I used before
    Do I need to fully reinstall SimTools ?
  7. Erwan960
    3,832Coins
    I reinstalled SimTools and it's the same thing.
    In SimTools, the "Virtual Axis" work fine : I can see moving Heave, Surge and Sway when playing PCars. I can also use "Axis Testing" without a problem.
    I think it meens : the plugin works fine and my simrig works fine. So, where is the problem ? Why my rig doesn't move when I play ? :)
    edit :
    I found where the problem comes from !
    It's in the pCARS_MaxMin.cfg : all the values (heave, surge, sway) have to be divided by 10. So 20 -20 have to be set to -2 2 and all works like a charm !
  8. value1
    14,305Coins
    With the update I also corrected the surge, sway and heave output from [m/sec²] to [g]. This morning I deleted my post after reading your
    Anyway I added this to the update report.
  9. value1
    14,305Coins
    Philosophically you're right :)
  10. Erwan960
    3,832Coins
    Hi !
    There is a new V5 shared memory since today :)
    Have fun !
  11. value1
    14,305Coins
    Thank you for alerting us.
    :) :( They're keeping us busy
  12. value1
    14,305Coins
  13. Volker Herre
    Volker Herre New Member
    383Coins
    SCN5
    Hallo, ich kann leider nichts darüber finden wie und vorallem wo hier die Plugins eingefügt werden.
    Vielleicht kann der eine odere andere mir hier ein kleinwenig hilfe leisten :thumbs
  14. value1
    14,305Coins
    Du installierst ein Plugin so:
    × Starte das Programm Plugin-Updater (oder so), das du im Installationsordner von SimTools findest.
    × Ziehe nun das Plugin (die ganze zip-Datei) mit der Maus in den Updater (drag'n'drop).
    × Nun schließt du den Updater wieder und startest SimTools GameManager.
    × Wähle die soeben installierte Simulation und clicke auf Patching.
    × Patche die Simulation.
    Eine genaue Anleitung findest du auch hier auf englisch: http://www.xsimulator.net/simtools-complete-documentation/
  15. RaceRay
    23,892Coins
    GUI is broken when a documentation is needed :D:rolleyes:
    *fast run away*
  16. value1
    14,305Coins
    :p Though I must agree to some degree (grumble)
    One of the targets for a future release of SimTools is indeed to simplify the whole plugin/patching process and make it more user friendly/intuitive.
  17. value1
    14,305Coins
  18. RaceRay
    23,892Coins
    Wuaaa.... 12.000 $ setup:eek:
  19. john
    john New Member
    328Coins
    With multi-screen (non identical screen) set up now open source ( SoftTh.net ) what is hardware entry level for running Project cars, and others. ?
    ie processor, memory, graphics cards, anyone experimenting ?
  20. value1
    14,305Coins
    It depends…
    "At the nVidia booth (Consumer Electronics Show (CES) in Las Vegas), Project CARS can be found running in triple-screen 4K Surround mode (that’s a staggering 11520 x 2160 resolution!) and powered by four nVidia GTX Titan cards."
    For us average users these are the minimum specs:
    CPU - 3.0GHz Dual-Core, 2.4GHz Quad-Core
    GRAPHICS - nVidia 9600 GT 512Mb, ATI Radeon HD 4750 512Mb, DX 9
    MEMORY - 2Gb RAM (3Gb-4Gb recommended)
    CONNECTION - Continuous Internet
    Assetto Corsa (my favourite simulation in development :thumbs):
    Minimum PC requirements:
    OS: Windows Vista, 7, 8, 8.1
    Processor: AMD Athlon X2 2.8 GHZ, Intel Core 2 Duo 2.4 GHZ
    Memory: 2 GB RAM
    Graphics: DirectX 10.1 (AMD Radeon HD 6450, Nvidia GeForce GT 460)
    DirectX: Version 11
    Network: Broadband Internet connection
    Hard Drive: 15 GB available space
    Sound Card: Integrated
    Recommended PC requirements:
    Processor: AMD Six-Core CPU, Intel Quad-Core CPU
    Memory: 6 GB RAM
    Graphics: DirectX 11 (AMD Radeon HD 7870, Nvidia GeForce GTX 660)
    DirectX: Version 11
    Hard Drive: 30 GB available space
