Question problem at the beginning with Arduino and IBT2
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Tomsix, Nov 17, 2019.
  1. Tomsix
    Tomsix Member
    Németország
    324Coins
    Everything based on the SMC3 tutorial already wired with the arduino uno r3 and two ibt 2.
    MODE 2 in code modified and uploaded to the board
    In the SMC3 program I set the initial parameters based on what was described
    if i rotate the knob moves the green line up n down and has a nice stable draw.
    the moment i turn on the power to the IBT 2 the usb connection seems to broken and nothing happens
    you hear some windows sound as the usb device disconnects itself and then reconnecting
    after that if I restart SMC 3 then I get an error message that it cannot connect to arduino
    does anyone have experience with a similar phenomenon?
    I would be grateful for any helpful advice
  2. Tomsix
    Tomsix Member
    Németország
    324Coins
    I forgot to write that if i connect everything and switch the power on to iBT2 and so connects to usb then it makes me black display for a moment.
    154,750Coins
    +11,196 / 57 / -2
    Sounds like a hardware fault.
  4. Tomsix
    Tomsix Member
    Németország
    324Coins
    I thought about it too, but how do I know that the IBT 2 chip is not working There is no LED lamp on it that shows ita communicates with arduino
  5. Tomsix
    Tomsix Member
    Németország
    324Coins
    have to try another code with another wiring maybe i get something
    there are similar projects on arduinos website
    154,750Coins
    +11,196 / 57 / -2
    Please post some pictures of your wiring and SMC settings.
  7. Tomsix
    Tomsix Member
    Németország
    324Coins
    I can not post pictures at the moment but, I have some news. so the fact is i'm not an electrician and i don't realy understand how it's possible but i managed to get things working :thumbs
    What is happend
    I connected a little 3V electric motor and a battery to the IBT2 and tryed it out then Voilaa it works
    Than i connected an 18V battery from an old drill machine and a wheelchair motor
    Works also
    the only problem with it that, it rotates faster in one direction than in the other:eek: i need to figure out why
    .IBT 2 doesn't seem to work on 24 v
    :think
  8. Tomsix
    Tomsix Member
    Németország
    324Coins
    What is happend
    Works also
    :think
