Bug Pro license Dof reality H3 When I patch dirt rally my steering wheel Does not work
Discussion in 'SimTools Pro & Entertainment Version' started by CrossyCB, Jun 23, 2019.
  1. CrossyCB
    CrossyCB New Member Gold Contributor
    156Coins
    I patched dirt rally for motion my Logitech race wheel then did not work in the game but when I remove the patch it seems to work fine. This in VR btw.
    150,584Coins
    +11,017 / 55 / -2
    It may be a usb port band width issue, what VR HMD are you using and is there an issue if the VR HMD is disconnected from the computer?
  3. CrossyCB
    156Coins
    I am using vive and dirt rally revive but when i use normal vive on il_bos none of my inputs register I also cannot get it to realize that im even running the games. The output testing also I can only get it to work sometimes please i so confused.
    150,584Coins
    +11,017 / 55 / -2
    The first step should be to use SimTools Output Testing to check that the motion rig behaves as expected. That should pin down if the issue is with the rig or peripherals and your computer.
    I suspect you may need to troubleshoot directly with DOFreality.
  5. CrossyCB
    156Coins
    for some reason I can get assetto corsa and project cars 2 working without sim tools and just using the sim racing studio thing. But those are the only games that I got working so I mean its a bummer I will try to conact dofreality.
  6. yobuddy
    50,295Coins
    Are you using any usb hub's by chance?
  7. CrossyCB
    156Coins
    Yes I am using A hub
    150,584Coins
    +11,017 / 55 / -2
    Can you please clarify what the "sim racing studio thing" is? Is it something that can create say a port conflict?
  9. yobuddy
    50,295Coins
    My guess is the hub does not have enough power to power all devices.
    If you can, will you please try it without the hub?
    (If you have to use the hub, use it only for things like your mouse and keyboard etc..)
    Chat soon,
