Power supply for SCN5
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by RonK22, Jul 4, 2009.
  1. RonK22
    RonK22 New Member
    This is my first post and I would like to say hello to all..my name is Ron Kelly (Ronk) and I live in Cincinnati, Ohio just a stones throw from bvillersjr if you look at the world map..I purchased a used Obutto Cockpit four months ago and spent much of that time adding things to give it a more relistic feel..while on youtube looking for new ideas for my sim I saw a frex for the first time... after a bit of searching on the Internet I found your site.. with all this sites information and all your helpful Members I felt secure enough to start my own motion sim project..well the easy part the frame work is now complete so on to the fun stuff the SCN5's...guess I should get to the subject of this post... the power supply I have is a SOLA SDN 10-24-100 is this a suitable power supply to power both SCN5's or do you for some reason need two separate power supplys?..
  2. egoexpress
    422Coins
    any data sheet?
    regards
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Welcome to X-Sim!
    From what I can see at this page http://www.sola-hevi-duty.com/support/inactiveproduct/Power Supplies/sdn.htm, the SDN 10-24-100 power supply has overvoltage protection and an adjustable output of 24VDC-28VDC. The SCN5 acuators should be fed exactly 24VDC. You should measure the output of your power supply with a meter and ensure that it is adjusted properly before connecting your actuators! With regard to amperage, each SCN5 actuator requires 2amps. The web page above claims that your power supply is capable of 10amps, so you should have no problem using it to power both actuators.
    Your power supply retails for $348.00 according to this site! An acceptable power supply for SCN5 actuators can be purchased for $24.00. If you have the option of returning the SDN, you may want to consider it.
  4. RonK22
    RonK22 New Member
    Thanks egoexpress and bvillersjr for your replys I will make sure and include a data sheet or link to the hardware in question...I got the SDN at a fleamarket for $10 while looking for laptop type power supplys it is puting out just over 24v acording to my cheepo meter I will test it with something better and adjust the power if nessary to exactly 24v...I need to get the RS485 to RS232 adapters, Serial cable and RS232 to USB adapter cables ordered this week...is there a tryed and true RS485 to RS232 adapter I'm looking at these on ebay anyone know if these will work they look to be the same as used in the Mr. Burns project..Thanks again Ron
    http://cgi.ebay.com/9-PIN-RS-232-to-RS- ... 7C294%3A50
  5. bvillersjr
    Ohio, USA
    438Coins
    I am aware of several people who were unsuccessful with the Hexin adapters. I am not able to recommend these adapters.
  6. RaceRay
    23,891Coins
    I had no problems at all with the hexin ones. They work fast and well. But you should use the right USB/RS232 adapter to bring them up without problems.
