Planning phase 2dof sim
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by skalleno, Jul 14, 2011.
  1. skalleno
    skalleno New Member
    Norway
    341Coins
    Hi, i have been surfing this fine site for some time now, and had to register to ask a few questions. I am currently planning a 2dof sim setup, primarly for racing. I am planning to use wiper motors. Would it be possible to use the VM110 for the interface? I know about the JRK12v12, but this is not aviable in my country, but the VM110 is aviable nearby. So if anyone could give me some info on this that would be great.
  2. skalleno
    skalleno New Member
    Norway
    341Coins
    Never mind. After some more reading, i see that the VM110 is used for pneumatics. Will order the JRK. :)
  3. bsft
    Righto then, you should be able to get the JRK shipped anywhere. Once you have them , feel free to ask my self or Shannonb1, aldoz, and eaorrobbie for assistance, as we are all running them.
    Thanks, David.
  4. eaorobbie
    20,506Coins
    Ok mate let us know when your ready to set them up.
    Recommend building a test motor setup before sim then once ya confident using x sim with the jrk , build the sim of your choice.
  5. skalleno
    skalleno New Member
    Norway
    341Coins
    Yes i will let you know when the building begins, but first it`s off for a 3 week holiday :)
  6. eaorobbie
    20,506Coins
    no worries mate. Write a description in ya post as ya build it mate.
    Helps to keep track of what ya doing with it plus we can add comments or questions plus its valuable for new comers to see how someone else achieved it.
    Enjoy ya holiday, come back safe.
  7. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    discuss with you wife would be great..you gonna need every second of your free time about 2 or three month..maybe more
  8. EL-CORAZON
    EL-CORAZON New Member Gold Contributor
    stavanger Norway
    372Coins
    Cant go wrong with jrk :hi: . I order mine from supplier in Sweden.my sim working better then I had hoped for :D
  9. bsft
    I run my jrks at 22.5 amps max current setting with heatsinks on the big chip, in a box with a fan on it. They run great!
    :D
  10. EL-CORAZON
    stavanger Norway
    372Coins
    outch.. 8) have mine at 8amp and small heat sinks on...and it is very strong motion still :thbup:
  11. bsft
    Everyone else runs their jrk's at a lower current rating than mine. I must be doing something wrong. I may have to shift the weight balance back on the frame a bit further.Anyway, they work and work well. The only thing that gets hot are the motors, even with fans on them. :thbup:
  12. bsft
    Then again, I do not know the average current draw, just the spike current draw, hence 22.5 amp max current.
