Pivot point preference
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by drzmat, May 18, 2020.
  1. drzmat
    drzmat Member
    184Coins
    What is the prefered pivot between a good old U joint and a cv joint for 2DOF and why?
    Thanks!
    153,697Coins
    +11,148 / 57 / -2
  3. drzmat
    drzmat Member
    184Coins
    I already did that, i was just wondering if i should get a u joint or a cv axle joint for my rig?
    153,697Coins
    +11,148 / 57 / -2
    Some CV joint allow lateral rotation and you don't want that, a u-joint has no issues.
  5. drzmat
    drzmat Member
    184Coins
    Perfect thanks!
  6. Erik Middeldorp
    Erik Middeldorp Member
    sheet metal worker
    Auckland, New Zealand
    651Coins
    What do you mean by lateral rotation? If you mean spinning like an office chair, I don't see how that's possible. I do think a CV joint might be less suited to axial loads (the weight of the rig and driver pushing down on it) as I think the direction of the grooves would tend to multiply the compressive forces on the balls.
    153,697Coins
    +11,148 / 57 / -2
    Here is an example: https://www.xsimulator.net/community/threads/how-to-slack-in-my-2-dof-simulator.8930/
