Parker linear actuators
Discussion in 'Motor actuators and drivers' started by tronicgr, Nov 13, 2007.
  1. tronicgr
    tronicgr
  2. Alle
    Alle Member
    283Coins
    I'm trying to find out the price of these actuators and a suitable electric motor to be used with them.
    They have a large number of solutions for electric cylinders.
    It seems that Parker offers only VAC motors (starting from +220 VAC)...or at least I have not found any 12 /24 VDC motors on their website.
    I will let you know the price as soon as I know.
    Regards,
    Alessandro.
  3. egoexpress
    I've sent an email with a price request to parker in swiss some time ago. And got a reply.
    These actuators cost the 10fold of the SCN5.
    But perhaps they sell their actuator without controller for less?
    ego
  4. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    I don't get it, do you think 100N is enough?
    I can easily achieve 400mm/sec with 1:1 with my linear actuator now. I dismissed it because it slowed down when I applied my body weight to it. I would guess I applied 20kg of resistance. We are now attempting to gear the drive down to 3:1 ratio with bicycle sprockets and chain.
    But it would be nice just to direct drive and achieve 400mm/sec using 24V marine bilge pump motors. I've never built a frex, would 100N be enough to move your weight around, 2 DOF on the pivot? 100N not enough for my 3 point system.
    I will post the linear actuator when it is completed.
    EvanF
  5. egoexpress
    The Frex just pulls/pushes you over the pivot.
    100N is definatly not enough for your torture seat, as the actuators have to lift you up. Even with the spring support underneath.
    Thats the great difference.
  6. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Hi ego,
    I would like to make a frex style chair to compare the 2dof and 3dof systems with Thanos' solution.
    With your experience with the frex, what do you think is a good target Newton force to aim for.
    I want to minimize the gear ratio so I can be as efficient as possible attaining max linear speed with optimum force.
    My gut feeling is 100N is light but if that is all that is required then I can achieve a lot of linear travel in 1 sec.
    evanF
  7. egoexpress
    Have a look at the scn5 specs. They have 10kgf at near zero Speed. And with 400mm/s they have near zero force.
    I think everything above 100N should be OK for a Frex-style sim.
  8. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Okay, I'll keep that in mind.
    I am seeing my engineering friend tomorrow to discuss how much/little force to go for. At present the motors I have chosen to use are 24V 4000RPM 100W. The pitch of the actuator is 12:1
    I'm thinking a 2:1 reduction gear between the motor and the threaded rod as a starting point and see if this will shift a chair on a pivot.
  9. Alle
    Alle Member
    283Coins
    Of course in my comparison spreadsheet, my idea was to reach 100N at 400mm/sec. This value is much more than what needed for a Frex like solution.
    A frex solution reaches 10N at 400mm/sec.
    With 100N at 400mm/sec I'm sure to feel bumbs and curbs and have enought power to move the seat also for very fast movements.
    Regards,
    Alle
  10. EvanF
    EvanF Member
    Multimedia Producer
    New Zealand
    423Coins
    Alle,
    I am mystified why Frex use the word 'reaches'
    It implies low power and inertia. 10N is not a great force and with PWM speed control, torque is already there at low speeds.
    It also implies the Frex design is very efficient.
    Do you know where I can find good blueprints of a frex design?
    EvanF
  11. Alle
    Alle Member
    283Coins
    EvanF,
    sorry for my english.
    What I meen is that SCN5 produces a force af 10N at 400mm/sec.
    I'm agree with you that Frex design is very efficent. At 200-250 mm/sec this electric actuator produces a force of about 20N, and with this low force is able to move efficently the seat.
    Regarding the blueprints of a Frex design, I'm sorry but I do not know where you can find them.
    I'm working on a Frex like solution right now. At the end of the project I will post everything (frame drawings, part list...ecc).
    Regards,
    Alle
