Question Paralleling BTS7960 drivers problem
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by SpeedBoy, Feb 3, 2023.
  1. SpeedBoy
    SpeedBoy New Member
    42Coins
    DC motor, Arduino
    Hey Guys, i am new to posting here so bear with me please
    I have an arduino leonardo EMC pro firmware based steering wheel with MY1016 250w motor.
    I was using single bts7960 driver with but it gets burnt so i parallel 2 of them they work nice with barely no heat but the octal buffer chip 74HC244D gets fried, i replace and it works again.
    I don't know what keeps frying it.
    If you know a solution it will be so helpful for me thanks in advance.
  2. Gadget999
    11,947Coins
    You may be able to solder 2x the mosfets on the board on top of each other !
    Also try fitting 2x heat sinks
  3. SpeedBoy
    SpeedBoy New Member
    42Coins
    DC motor, Arduino
    I have already put a heat sink on top of the chips.
    You mean i can install two bts7960b chips on top on the original ones and use a single driver instead of paralleling 2 whole drivers?
    Won't that make the resistance of the chips half the original value and may affect the buffer chip or not?
  4. wingert
    wingert Active Member
    642Coins
    4DOF
    The 74HC244D is a CMOS chip with an I_out of +/- 35 mA. If the load of 2 driver exceeds this Limit it will burn up. Drive a simple Power-FET with heat sink, there plenty on market.
  5. SpeedBoy
    SpeedBoy New Member
    42Coins
    DC motor, Arduino
    Do
    Do you have any guide on that with the existing driving modes in EMC software please?
    How does the current increase every driver board has its own buffer chip?
  6. Gadget999
    11,947Coins
    Its worth trying if you are prepared to fry one to find out !
