osw does not work with simexperience scn5
Discussion in 'Direct Drive Wheels' started by chris1962, Jun 26, 2017.
  1. chris1962
    chris1962 New Member
    325Coins
    3DOF, SCN5
    Hi guys,
    I have a problem to conect an OSW small mige together with my simexperience scn5. Every time when I try to plug in the usb conctions my scn5 usb conection is stepping out and does not work anymore. I have installed new windows upgades and all driver but without any success. Does somebody know why this could happend any time again?
    Any help wuold be fantastic!
    Many thanks in advance
    Chris
  2. Pit
    30,503Coins
    Hi, first try different USB slot combinations, plug out other USB devices you don't need at the moment, try out an USB hub, if no success try new USB cables.
  3. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    I have that combination so i can tell you it does work. Are you plugging the correct usb connector off your stm board. If its a simucube i cant help as much
  4. chris1962
    325Coins
    3DOF, SCN5
  5. chris1962
    325Coins
    3DOF, SCN5
    at first many thanks for help! I found the problem. It was a bad usb conection. Now I use an actice usb cable and it works fine!
    :thumbs
