News New open firmware for Sim Motion
Discussion in 'SimTools compatible interfaces' started by Hoantv, Jun 28, 2022.
  1. Hoantv
    Hoantv Active Member
    981Coins
    AC motor, Arduino
    Hi all,
    I am Hoan from VNM Simulation, After VNM wheelbase force feedback firmware, I am developing a open motion controller firmware. Some features:
    - control 8 servos simutanously.
    - pulse frequency 125khz per each servo that enough with current servo which most people use 2500ppr and 3000 rpm
    - Software interface intergrated with current VNM config
    - you can buy a cheap development kit ~ 13$ to use
    - use with FlyPT Mover
    Here is my channels to discuss :)!
    Facebook group:
    https://www.facebook.com/groups/2303223886447618/?ref=share
    Github:
    https://github.com/hoantv/CarSimulatorFirmware
    Discord: https://discord.gg/eg9bA2j8QS
    Here is the result i captured 8 pin simutanously at 125khz.
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Hoantv!
    I dont understand exactly what your firmare is made for. Lot of us have the following configuraton:
    Game -> Simtools or mover-interface -> controller like Thanos or Odrive-> motors for actuators.
    For force-feedback wheels and similar equipment, we have little different configuration:
    Game -> force-feedback controller -> motor driver -> motor for dd-wheel or so.
    Could you pls. explain, where to use your firmware? Is it something similar like the Thanos? Which hardware could we use then?
    Maybe you could make a scetch of the whole configuration?
    Thanks a lot!
    Wickie
  3. Hoantv
    981Coins
    AC motor, Arduino
    The same flow as you know: game -> mover-interface software-> motion controller -> motor controller -> servo/motor.
    My firmware is for motion controller. I tested with STM32F401 and this board will be use for DIY
    https://www.digikey.com/en/products/detail/stmicroelectronics/NUCLEO-F401RE/4695525.
  4. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    HI. Hoantv! Can I test your developed motion controller firmware?
  5. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    so it cant be used with simtools interface..??
  6. Hoantv
    981Coins
    AC motor, Arduino
    Yes. Im writing document to release. Wait few days
  7. Hoantv
    981Coins
    AC motor, Arduino
    Yes. Can use simtool
  8. Hoantv
    981Coins
    AC motor, Arduino
    I have just released VNM motion controller firmware with its manual.
    - STM32F401RCT microcontroller with 25 MHz crystal
    - Supports up to 8 actuators
    - Supports up to 250 kHz PWM frequency with <= 6 actuators and 200 kHz with <= 8 actuators
    - Input for soft Emergency stop, Servo ready, Torque reach (stroke limit detection)
    - Can be used with some motion softwares like FlyPt Mover, Simtools or similar which support configurable string output.
    With this firmware you can make your motion controller from 50-> 100 usd.
    pls check it here https://github.com/vnmsimulation/VNM_MOTION_CONTROLLER
  9. Hoantv
    981Coins
    AC motor, Arduino
    #vnm_motion_firmware
    Release V1.0.3.0
    - Supports up to 9 actuators.
    - Supports up to 500 kHz pulse frequency.
    - Generates exactly the number of pulses that a servo driver needs to rotate one round.
    - Filtering for smooth movement.
    - Support belt tensioners without feature on motion software (on development).
    - Loop time is 1ms
    - Can be used with some motion software like FlyPt Mover, Simtools, Sim-motion software or similar which support configurable string output.
    wiring, setting in the repo:
  10. zhai1987
    zhai1987 Member
    320Coins
    Has the project updated anything interesting?
    150,542Coins
    +11,017 / 55 / -2
    Check out the provided links to the GitHub pages to see if you are interested in the wheel or controller aspects.
    @Hoantv's comment about listing the controller on GitHub seems to be some of the most recent activity. That said the motion controller aspect is pretty new and @Hoantv is trying to share the possibility for use. I am not aware of anyone taking that up yet for the motion controller, but there is past activity and some old issues identified with respect to DD wheels.
  12. cfischer
    Colorado
    2,727Coins
    @Hoantv Any info on how to get it running with a dev board?
    Watching with interest.
  13. zhai1987
    zhai1987 Member
    320Coins
    Controller, does he still support DIY? Is there a tutorial?
  14. noorbeast
    150,542Coins
    +11,017 / 55 / -2
    We will need to await further advice from @Hoantv, the code is available via Github, but we will need to find out if a tutorial has been done, as I am not aware of a member trying this out yet. @Hoantv has not been around for a few weeks so you may need to be a little patient, as I expect he will respond when he can.
  15. Arta Yasa
    Arta Yasa Member
    824Coins
    This is suport simhub motion sir??
