New 5 DOF sim platform
Discussion in 'DIY Motion Simulator Projects' started by CW, Aug 3, 2007.
  1. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
  2. RaceRay
    23,875Coins
    1 axis for rotation
    1 axis for hub, up and down
    1 pivot knuckle for 2 degrees of freedom
    Total is a 4DOF simulator, that sounds like a big challenge :wink:
    How do you want to move it, with pneumatics or elektric actuators?
    Kind regards
    RaceRay
  3. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Re 5 DOF
    Gidday RaceRay, It will be 5 DOF I didnt show that the whole thing will sit on a ball race (like a lazy susan in a straight line) for sway. I went on a 737-800 the other day and the sway was one of the most prominant movements. If it has to be 4 then I will lose yaw.
    I am losing a bit of sleep at the moment (4:00 am is my best thinking and design time) over how to power it, if you have seen my other sim you will see that it is 12volt electric with auto power steering racks,now this works ok (refer carsim.mpg) but i need more power especially for the heave.
    I am probably going for single phase 230volt mains motors and I am going to check today (another 4:00 am idea) that an old washing machine agitator set up may work OK for heave and some homemade linear actuators made from sissor jacks for the others, because the sim is in a house and accidents do happen I want to keep away from potentially messy hydraulics (cost factor as well) I would rather spend the real money on the visual system.
    regards
    CW
  4. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Just a footnote,the linear actuators are working well and I am not going to use sway at this stage, so back to 4 DOF. I cant get a high enough frequency for realism may revisit later and can easily modify the platform to accomodate two more axis.
    The platform is nearly complete apart from the wiring. So motion trials will start in about two weeks.
  5. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Gidday Sirnoname
    If you mean the roll/pitch knuckle it is the driveshaft off a Hyundai Pony, the polished part is the thrust surface for heave. The last simulator shaft was fine with 300 kg weight for the life of the sim in fact it still lives in the car sim.
  6. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    It is the shaft between the gearbox and differential in a conventional rear wheel drive car, the shaft is about 75mm in diameter with the universals of about 25mm in diameter and a mounting flange on the end, designed to take torsional loads of many newton meters, perfect for a heavy sim!
