My Sim Cockpit [2dof 24v]
Discussion in 'DIY Motion Simulator Projects' started by dedraro, Dec 3, 2016.
  1. dedraro
    dedraro Active Member
    81Coins
    06/30/2017
    350W 2Dof
    My 2dof Sim
    12/03/2016: Hello to all guys, I present my current cockpit, had initially idea to build me a 4dof, 3dof heave + traction loss, then I decided to do things step by step, and to start with a simple 2dof, begin by showing you My cockpit as it is:
    Case created entirely by me, with only sections and aluminum panels
    Pc Spec:
    CPU: Intel i5 4690k
    VGA: 2x Sapphire 390 r9
    RAM: HyperX Fury 2x8gb
    HDD: WD 1TB + SSD 240GB
    ALI: Thermaltake 730W
    MB: MSI Z97 Gaming 5
    OSW small mige 5000ppr with IONI Pro HC at 800W, totally build myself
    Another thing that I have tried has been printing in 3D, and I just realized this button plate and magnetic paddle shift, really a great feeling.
    Sistem of bass shaker composed of 4 Reckhorn bs-200 powered by a e400 amp, 2 under pedals and 2 under seat, and another 2 basspump III with a konig 2400 under steering wheel and seat.
    I added the rubber to isolate each element that has transducers (pedals, seat, steering wheel) to increase even more the feelings that come to the driver, as I isolated the station off the ground, creating many levels:
    Silent Block
    Block in MDF
    Vibration mat
    The vibrations on the ground so they decreased by 80%, a remarkable achievement, and I can unleash my thomann E-400 and the konig 2400 without disturbing neighbors. ;)
    "Hydraulic" pedals a grind that has stretched for more than two months, it will not be beautiful it easy to adjust but I reached a top result with virtually feeling range of brake and clutch worthy of the most expensive in business.
    P260 potentiometers with brackets for the model servant Alu and shielded cable to prevent any disturbance
    always made in 3d support.
    All pedals are equipped with air shocks, and the brake has a Mavin load cell
    ARC Carbon sequential shifter, Fanatec CSS 1.5 and DIY handbrake from g27 pedal with gteye spring.
    • Like Like x 8
  2. dedraro
    81Coins
    Now I ordered all the pieces to build me a 2 dof classic for the seat only, the motors 24v are the first to have arrived. See you soon. ;)
  3. spyderwash
    spyderwash genesy sim
    italy varese
    - 149Coins
    2DOF, 3DOF, Arduino
    compliments beautiful project and with excellent base for make it dynamic
    complimeti bel progetto e con ottime base per renderla dinamica
  4. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Magnifique travail !
    frein a une cellule de charge Mavin : peut-on savoir quel modèle et quel force ? Merci.
    Wonderful work, super OSW wheel !
    "the brake has a Mavin load cell": can we know what model and what strength? Thank you.
  5. dedraro
    81Coins
    Thank you spyderwash i will try to get the sim the much compact possible ;)
    Thank you momoclic, this is the load cell, 100kg version:
    https://it.aliexpress.com/item/Taiw..._8&btsid=0731edb3-dd36-47ec-a36b-44acf75bbb17
    (another seller a truth, but one from which I bought it I did not have more).
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    1,949Coins
    Very nice rig and project ! I really appreciate the quality of your design.
    Where did you buy these motors ?
  7. dedraro
    81Coins
    I am attaching directly to the link from where I bought them:
    https://it.aliexpress.com/item/24-V...IphJHs&detailNewVersion=&categoryId=100007153
    it also sells the site Simukit:
    https://simukit.com/moteurs/9-moteur-120w.html
    but his are both right, from China it took them about 10 days unfortunately I paid customs duties, and so I came a little more as the price, if you no have problems of space and you can use both right motors, buy them on Simukit. :)
  8. se041
    se041 New Member
    IT Process Mgr.
    Paderborn - Germany
    278Coins
    Hi there!
    Looks interesting. And great work with those pedals!
    Which controllers/drivers are you going to use for the motors?
    I'm also in the planning of my 2dof project and thinking about 12V vs. 24V.
    regards
  9. obobo
    obobo Active Member
    1,323Coins
    It is true that having a right engine and a left is practical
  10. dedraro
    81Coins
    Hi, thank you, i'll use this motor driver
    http://www.ebay.it/itm/Double-BTS79...id=100033&rk=2&rkt=8&mehot=pp&sd=111140003697
    with appropriate modifications for cooling as heat sinks, fans, and thermal paste.
  11. ferslash
    ferslash Active Member
    4,798Coins
    man! nice build.... :D i really liked your wheel pads (the 3d printed ones) it would be really nice if you post the 3d printer files :D:D:D
    keep posting
    fer
  12. dedraro
    81Coins
    Hi, thank you, this is the file .stl that I made for print :)
    https://www.dropbox.com/s/yp90j3zile2pi5b/Plate.stl?dl=0
  13. ferslash
    4,798Coins
    downloaded :D will give'em a try in the 3d printer :D
  14. dedraro
    81Coins
    good luck :D
  15. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    What a beautiful cockpit!:thumbs
    Did you design/build the pedals all by yourself?
  16. Blame73
    Blame73 Well-Known Member
    8,255Coins
    Hi, nice build so far!
    Where did you get the aluminum panels? Here (Sassari) I find them hard to find
  17. dedraro
    81Coins
    Hi, thank you, yes, the design is my own, but I was inspired by some projects around the web as:
    https://chippedwood.wordpress.com/2015/09/03/diy-hydraulic-load-cell-sim-racing-pedals/
    https://forum.virtualracing.org/showthread.php/90854-Mein-DIY-Cockpit?highlight=martin+ascher
    Ciao Blame73, tutto l'alluminio lo compro sempre da motedis.com, provengono dalla Germania ma le spedizioni costano comunque 13€, inoltre hanno davvero di tutto, dai profilati alle lastre in alluminio, viti, condili, molle, cuscinetti e quant'altro basta solo cercare, tutto ciò che vedi della struttura della mia postazione proviene da quel sito. :thumbs
    Hello Blame73, all aluminum I buy always motedis.com, come from Germany but shipments still cost € 13 also have really everything from profiles to aluminum plates, screws, condyles, springs, bearings and other, all you see of my cockpit structure comes from that site. :thumbs
  18. Blame73
    8,255Coins
    I'm taking a look at their website, it's great!! they've got more than everything I needed, thanks for the info.
  19. My.stAr
    Engineer
    1,064Coins
    DC motor
    Thanks for the links @dedraro
    How much did you spent for the parts? (pedals)
  20. dedraro
    81Coins
    I think around 450/500 euros, bearings, load cell and air shocks are the most expensive parts. :S
