My motion simulator
Discussion in 'DIY Motion Simulator Projects' started by steelsim, Oct 15, 2007.
  1. steelsim
    steelsim New Member
    1Coins
    Hi all
    Here is my setup:
    [​IMG][​IMG]
    Its work really fine with: velleman, festo valves and 3 speed softmotion.
    (especially with NFS)
    But i have a few problems:
    - sometimes my sim going to end of one axes (x or Y) and dosesnt respond to profiler signals;
    - how can i do 3-rd DOF (second velleman or sth);
    - force profiler crashed when i define crash effect on LFS;
    - force profiler usually crashed when i try to save settings;
    - does anyone could send me *.rnr file for 2 axes in LFS?
    Thanks for help
    and sorry for my english
    M
  2. egoexpress
    422Coins
    WOW, that's great! Good job! :gut:
    Is there a possability to get some higher resoluted pictures of your sim?
    Or perhaps a video? I really would like to see it in action!
    ego
  3. yobuddy
    51,679Coins
    Looks quite impressive! :eek:
    There are a couple of .rnr files for LFS here.
    http://www.x-simulator.de/forum/user-profiles-f4.html
    I would give Thanos’s DC motor .rnr file for LFS a shot; it looks great when using the RNR-3D-Simulation app.
    Make sure your cfg.txt for LFS has been modified to look like this at the end of the file.
    Conn To Master 1
    OutSim Mode 1
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 4123
    OutSim ID 0
    OutGauge Mode 1
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 4124
    OutGauge ID 0
    And defiantly post some high resolution pictures.
  4. steelsim
    steelsim New Member
    1Coins
    config.txt its ok, because g-force effects works, force profiler received signals and LFS sender plugin works....
  5. egoexpress
    422Coins
    Check your pots. This can happen if the pot signal is jittering at the end points of the pot while the calibration run.
    Second velleman and second Profiler
    ? Dont know
  6. steelsim
    steelsim New Member
    1Coins
    ill check this
    and second (third) cpu?
  7. egoexpress
    422Coins
    You should be able to run two Profilers on one machine. You'd have to activate it in the registry.
