Showroom my economic hydraulic brake
Discussion in 'DIY peripherals' started by MarcoMade, Apr 10, 2019.
  1. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    hello to all simracing pilots.
    I show you some pictures of my hydraulic brake
    built with a few coins.
    brake master cylinder for quads
    caliper used aprilia scooter (piece of wood for braking deformation)
    sensor 1000psi 0-5v approx
    arduino Leonardo (for steering wheel and pedals)
    I found it difficult to find the right Y-shaped diverters for hydraulic oil, so I welded a rim straight to the bolt and then drilled to pass the oil.
    pictures work in progress
  2. Timbo
    Timbo New Member
    40Coins
    I was thinking of doing something similar. Why do you need a caliper? Couldn't you just use hydraulic line directly to the pressure sensor?
  3. MarcoMade
    italy
    157Coins
    hi timbo. without the pliers, there is no pressure on the discs and it becomes very dimmable. I have little travel, the pump piston is small, if I wear hard rubber instead of wood it does not reach 100% (5v sensor output). in addition I have the possibility to purge air from the pipes as in the automotive industry ..
  4. MarcoMade
    italy
    157Coins
    I must have explained myself wrongly in the post above.
    without minimal elasticity, you reduce the feeling of braking a lot.
    which is why I mounted a clamp that presses on a wood
  5. Timbo
    Timbo New Member
    40Coins
    Ah, yes, I can see how allowing for some travel would give a progressive feel. And, of course, the ability to bleed the brakes is a must. Continue on, Sir.
  6. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    pressure transducer is kind of cheapes, easyest, and greatest solution...
    love your setup...
    but thats too expensive in my place...
  7. MarcoMade
    italy
    157Coins
    thank you. but he thinks that the pump I paid him 10 €, the pressure transducer 15 € and the brake caliper found of recovery with the tubes. I don't think it cost much. I can assure you that the feedback you give me compared to the load cells I tried has no equal .. I can brake like in a real racing car (cheap :)) ..
  8. ahoenksiluman
    indonesia
    89Coins
    for master, hose, and caliper thats cheap, we can use whatever it from...
    but the pressure transducer...hard to find and expensive...
  9. MarcoMade
    italy
    157Coins
    I'm not sure if I can post a link to the pressure sensor. however we are around € 15-25 depending on the model. 0 to 5v out signal 1000psi
  10. ahoenksiluman
    indonesia
    89Coins
    actually around $10 shipped from china for 500psi....
    but for now i cant afford it...maybe later...
  11. MarcoMade
    italy
    157Coins
    in fact this is how I did, I took a pump and sensor in china from one of the many stores
