motors have noise in middle position
Discussion in 'Motor actuators and drivers' started by mimakez, Jan 10, 2016.
  1. mimakez
    mimakez Member
    263Coins
    I made a simulator modeled on RacingMat 2 dof wiper and I use 10k cermet pots.I use RacingMat arduino code and settings. Simulator work great but when the simulator returns to its initial position after the race I hear noise from motors ( sometime left motors, sometime right motor, sometime both motors have noise). when I go after driving in simtools / game engine / output testing / axis output and manually move the slider axis1 and axis2 left / right and back to zero position then the engines stop to the noise.
    if someone had a similar problem and how to solve?
    thanks in advance
    153,788Coins
    +11,150 / 57 / -2
    Can you post a video of the motors making the noise, that would help a lot with troubleshooting.
  3. SeatTime
    I would say it is noise on the feedback line, try installing suitable capacitors on the active feedback line to earth. - It has been talked about before - try searching the site for the thread.
  4. mimakez
    mimakez Member
    263Coins
  5. mimakez
    mimakez Member
    263Coins
    Thx, I try with capacitors
  6. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    how much of the travel of your potentiometers are you using?
    180 degrees?
    if so then you can increase the tollerance value in the arduino scetch from 20 to 30.
    the line in the code goes like this:
    int Tol=20
    change it to 30... save.... upload.... and see if it solves your problem(it probably will).
  7. Pit
    30,510Coins
  8. mimakez
    mimakez Member
    263Coins
    Hi @pipis2015 I change int Tol to 30 and I have same problem. whether to try running with a 40 or 50?
  9. pipis2015
    Athens, GREECE
    10,248Coins
    You can try 40 or 50.
    It is 40 out of 1024 values of the analog to digital converter.
    So your simulator gets 1% less responsive every time you increase the tolerance by 10.
    How much is your pot travel?
  10. mimakez
    mimakez Member
    263Coins
    My pots travel around 75 degrees up and 75 degrees down. I use this code.
  11. pipis2015
    Athens, GREECE
    10,248Coins
    If you use racingmats code you should be OK with a tolerance value between 20 and 30.
    so stay with 30 and change this part to ease on the jitter.
    from this:
    if (gap>50) pwm=215;
    if (gap>75) pwm=235;
    if (gap>100) pwm=255;
    to this:
    if (gap>50) pwm=225;
    if (gap>100) pwm=230;
    if (gap>150) pwm=235;
    if (gap>200) pwm=240;
    if (gap>250) pwm=245;
    if (gap>300) pwm=250;
  12. mimakez
    mimakez Member
    263Coins
    I write this in code, everything works fine but I still have after the game to move the slider axis1 or axis 2 or sometimes both at -2% and then be all right. if I do not then I hear the noise of motors.
  13. pipis2015
    Athens, GREECE
    10,248Coins
    what voltage are you running your motors with?
    12volt or 24 volt?
  14. mimakez
    mimakez Member
    263Coins
    12volt
  15. pipis2015
    Athens, GREECE
    10,248Coins
    are you using the ultrasonic code? or the standard code?
  16. mimakez
    mimakez Member
    263Coins
    I use standard code
  17. pipis2015
    Athens, GREECE
    10,248Coins
  18. Pit
    30,510Coins
  19. mimakez
    mimakez Member
    263Coins
    yes, I try ultrasonic code but something not good. when I put ultrasonic code only axis1 work with strange vibrations. I must see what is wrong.
  20. pipis2015
    Athens, GREECE
    10,248Coins
    racingmats' ultrasonic code does not work with all h-bridges (if you have monstermoto it should work).
    this is as far as i can help.
    I didnt find any thread with your project.
    If you can ... create a thread to present your simulator and post some pictures and specifications of the parts so others who have similar constructions can help you.
