Motors Faster in one Direction only
Discussion in 'New users start here - FAQ' started by Chris Twigg, Jan 7, 2022.
  1. Chris Twigg
    Chris Twigg New Member
    - 87Coins
    Hi Guys,
    First of all i'd like to thank you for an amazing project!
    I have a simple 2DOF Setup
    1 x arduino mega
    1 x Sabertooth 2x32
    2 x 24v Mobility Scooter motors
    2 x 24v Power Supplies
    60mm Arms
    All setup, motion, software, sims work as expected with one exception.
    Motion in one direction is slower than the other.
    Surge forward = both motors push forward at 100% speed
    Surge Backwards = both motors pull backwards at approx. 50% speed.
    This applies to SMC3 software (one motor at a time) and Simtools (both motors)
    I have followed the guides with reference to sabertooth dip switches and config and tried all permutations of settings in SMC3
    Any ideas?
    Many thanks
    Chris
  2. Gadget999
    11,953Coins
    Is there a setting for smc3 cw and ccw pwm ?
    Use the smc3 utility
  3. Chris Twigg
    - 87Coins
    Thanks for for reply
    From memory the DEScribe application doesn’t have those settings… but I will double check.
    thanks again
    Chris
  4. Chris Twigg
    - 87Coins
    I cannot find any settings referring to cw & ccw speeds in either SMC3 or DEScribe. I thought i was on to something with Exponential settings but sadly not.
  5. Gadget999
    11,953Coins
    are your pwm and pwmrev settings both at 255 ?
  6. Chris Twigg
    - 87Coins
    yes, I’ve tried pwmrev at 0 and 255
    I’m going to disconnect the seat today to ensure the testing isn’t torque biased. The centre of gravity of the frame on the UV joint naturally falls forward without weight in the seat.
    if that all tests ok, I will try changing the arduino software from @BlazinH to another
    150,722Coins
    +11,018 / 55 / -2
    Just to clarify, are you using @BlazinH's modified SMC3 for Sabertooth?
  8. Chris Twigg
    - 87Coins
    yes
