News motion simulator videos
Discussion in 'DIY Motion Simulator Projects' started by andres50, Jan 26, 2021.
  1. andres50
    andres50 simulador de vuelo (flight simulator 2020)
    mecanico
    pamplona
    - 254Coins
    Hello, here I upload the videos of the simulator that I have built, I hope you like it. All made with recycled materials such as PVC, cardboard, iron, wood, three slightly old monitors, what I had at home and many hours.
    150,686Coins
    +11,018 / 55 / -2
  3. andres50
    mecanico
    pamplona
    - 254Coins
    Thanks to you, for the gear changes, I am working on it and as you have observed in the video, the cardan has a small rotation, I bought it in a car junkyard and it has some play if I see that it gives me problems I will change it. :):thumbs
    150,686Coins
    +11,018 / 55 / -2
    A flexing cardan will soak up some of the fine motion details, it is up to you to determine if it is significant enough to fix or not.
    You can replace the cardan with a bigger one or alternatively keep the existing cardan use panhard rods between the top and bottom frame.
