Motion Cancel for vive Cosmos please help.
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Patte83, Sep 24, 2020.
  1. Patte83
    Patte83 Member
    24Coins
    Hi everyone !!
    I did just see this clip on Youtube. This guy have vive cosmos OG and it looks like it is working with Motion cancellation.
    Do any one know how this can be done ? Please i have looked for a solution for this since i got this headset.
    If anyone know how to please send me instructions please !
    Youtube clip
    150,602Coins
    +11,017 / 55 / -2
  3. Patte83
    Patte83 Member
    24Coins
    Nice so all i need to do is to buy a vive tracker and mount it on my rig and set it up?? :D
    or do i need a base station as well ?
    Thank you
    150,602Coins
    +11,017 / 55 / -2
    The Cosmos in not a tested device so best to get some advice from @Dschadu as the best way to test it.
  5. Dschadu
    Dschadu Active Member
    1,935Coins
    Best solution would be a tracker that works natively with your HMD.
    With OVRMC you cannot mix two tracking systems, in this case Inside-Out (I think some kind of WMR?) tracking and Lighthouse.
    The systems do have a different understanding where "0" is in the world. OVRMC does not support this yet.
    To answer your other question: If you want to use a lighthouse tracked device, i.e. the Vive Wand, you also have to buy two base stations as the tracking is outside-in, meaning it relies on external sensors / laser.
  6. KydDynoMyte
    RTP, NC
    44Coins
    They do have a vive tracker on the rig you can see, but since they seem to have most of the yaw axis disabled they might just be using the IMU that is on the YawVR. Someone has added YawVR Tracker support to OpenVR Input Emulator. Since it's rotation movements only, an IMU works fine, even for yaw if it doesn't drift bad. I am a little surprised 2dof sims haven't been using something like a wii mote for motion cancellation.
    I think people that mix tracking systems use OpenVR-SpaceCalibrator to align the two systems.
    The lighthouse face plate for the cosmos and a lighthouse tracker or controller would work best.
  7. Patte83
    Patte83 Member
    24Coins
    Ok thanks a lot
