Mini racing Simulator
Discussion in 'New users start here - FAQ' started by Sergey Komarevtzev, Jul 12, 2014.
  1. Sergey Komarevtzev
    Sergey Komarevtzev New Member
    297Coins
    I build a small version of racing simulator. It is good for understand the way simulator works and the Axis moves. but i have some problems to set the YAW axis with ROLL together.
  2. eaorobbie
    20,506Coins
    Which code are you using ?, mine can be sorted quiet easy, and its for SimTools not Xsim.
  3. Sergey Komarevtzev
    297Coins
    sorry i use the SimTools to ... i wrote by mistake.
    the code:
    #include <Servo.h> // the servo library
    #define SERVOS 2 // the number of servos
    int servoPins[SERVOS] = {9,10}; // servos on pins 7 through 10
    Servo myservo[SERVOS];
    void setup()
    Serial.begin(9600);
    for(int i=0; i < SERVOS; i++)
    myservo.attach(servoPins);
    void loop(){
    serviceSerial();
    void serviceSerial()
    static float pos = 0;
    if ( Serial.available()) {
    char ch = Serial.read();
    if(ch >= '0' && ch <= '9')
    pos = pos*10 +(ch - '0');
    else if(ch >= 'a' && ch <= 'a'+ SERVOS){
    myservo[ch - 'a'].write((pos/255)*180);
    pos = 0;
    the code is Arduino uno for Servos.
  4. eaorobbie
    20,506Coins
  5. Sergey Komarevtzev
    297Coins
    where i can find this working code that you talking about?
    and i can't find something about the axis assignments some tutorial to define it right ...
  6. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
