value1
Microsoft Flight Simulator 2004 (FS9) Plugin 2.0.0.1
SimTools game plugin for Microsoft Flight Simulator 2004 (FS9)
  1. value1
    14,184Coins
    Microsoft Flight Simulator 2004 (FS9) - SimTools game plugin for Microsoft Flight Simulator 2004 (FS9)
  2. jsmith2307
    jsmith2307 Member
    Respiratory Therapist
    Corpus Christi, Texas
    324Coins
    2DOF, DC motor, Arduino, Joyrider, Motion platform
    Greetings,
    I'm trying to download FS 2004 plugin, and can't. I've only got 82 coins.
    What is procedure for coming up with more?
    jsmith2307
  3. BlazinH
    16,677Coins
    You could spam the site like @shannonb1 is doing right now and risk being banned altogether but I actually don't recommend this!!!!!!!!
  4. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Woah woah, im not spamming, im trying to be active. Trying to get to that 250 and im 3 coins away. Not trying to be annoying, I'm just looking around and seeing how all this works now. For the record Im not posting links to Miley Cyrus videos or anything.....Would I get more coins for that =)
  5. BlazinH
    16,677Coins
    You just admitted to posting all of your previous post for the purpose of getting more coins. While you may be contributing somewhat with you're comments I still call that "spamming"!
  6. Historiker
    Michigan USA
    9,214Coins
    He is using the system as it has been created. At least his comments are pertinent rather than "Good Job" like others I have seen (what was that collection of numbers that guy used?) :D
  7. BlazinH
    16,677Coins
    Actually in an attempt to give you a real answer @jsmith2307 I don't know why you don't have enough coins now because you have been around for awhile already and made several posts. Maybe when the system was switched to the coin system you didn't get what you had coming! In any case ask @RaceRay if he is willing to give you access to download it or I will give you some of my coins to purchase it if necessary!
  8. value1
    14,184Coins
    ROTFL :grin
    @362442340 it was called :)
    Nevertheless, we all are glad you finally got your 250 coins!
    Close to :p
  9. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings,
    The situation resolved! Thank you to those of you that responded to my plea. In particular I'd like to thank BlazinH for the kind comments and Historiker for the coinage!! At the moment, I am downloading the plugin! More to come!
    jsmith2307
  10. value1
    14,184Coins
    @jsmith2307: Don't forget to also download and install the FSUIPC for FS 2004, which you can find at Peter Dowson's Support Forum.
    This is not included in the plugin and is necessary for the plugin to work.
  11. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    value1,
    I've been running Prepar3d 2.1 and previous versions for about two years now.
    I DO use the paid version of FSUIPC and it's great.............and inside the root of Prepar3d, I do have the modules folder with FSUIPC files in there.
    ?? - When I'm finished with my platform build and ready to go - I know to d/l the plug-in for Prepar3d......and how to patch it.....
    IS there anything I have to do "other than having FSUIPC installed?? - I know it uses simconnect - but just don't know what I'll need to do in reference to that.
    Thanks so much for your valuable info.
    Tom
  12. BlazinH
    16,677Coins
    Yes, Value1 would be the one to ask here for a definitive answer I would think! But I will take a shot and see if I'm correct. I don't believe that FSUIPC is now required for FSX or P3D because it's use is not stated in the plugin. I believe the simconnect SDK is used directly so there is no need for FSUIPC to be installed. There is no simconnect available for FS2004 so FSUIPC must still be used for it however. As to whether you will be able to still use FSUIPC with the plugin also is unknown to me but my "assumption" is that you should be! I hope I don't end up you know where!:eek:
  13. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Hi BlazinH,
    Thanks my friend. Hopefully you're correct - I have read "somewhere" else, that it still requires FSUIPC - just can't remember where as it's been about a year ago.
    When I get there (which won't be too much longer) - I/We will sure find out.
    Blessings,
    Tom
  14. value1
    14,184Coins
    There's no guessing needed: FS9 requires FSUIPC, FSX and P3D don't.
  15. BlazinH
    16,677Coins
    So now we know for sure that FSUIPC is not a requirement for using the SimTools plugin for FSX and P3D. But I again assume @cthiggin that since you are not using motion yet that you are using FSUIPC for other reasons. That is why I stated that I didn't know for sure if you could still use it when using the plugin also but I would think so since Simconnect must allow for multiple clients for multiple add-on's. And FSUIPC may not even use simconnect because it originally used memory offsets prior to FSX and still may.
  16. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    value1,
    Thank you for confirming that we're ready to go with FSX & P3D - appreciate it.
    BlazinH,
    Now WE know for sure. I use FSUIPC for calibration of my Saitek X52Pro - reverse throttles etc., as well as my CH Pedals - I also use lua for a couple items.
    Thanks so much fellow for the info and confirmation
    Have a blessed day.
    Tom
  17. DOFreality
    DOFreality Member
    Montreal
    344Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 6DOF
    can't get the motion out of SimTools
    what is the trick?
    do I need to register FSUIPC ?
  18. yobuddy
    51,380Coins
  19. DOFreality
    DOFreality Member
    Montreal
    344Coins
    Did all that, still no motion
  20. mastrohead
    mastrohead New Member
    italy
    210Coins
    Good evening to everybody.
    Have you solved FS9 compatibility with DOF P3?
    thanks,
