Question Memory Hooks depend on connected USB devices
Discussion in 'SimTools Plugins' started by MarkusB, Dec 29, 2020.
  1. MarkusB
    4,213Coins
    Hi Plugin developers,
    have you ever had the case that the pointers you found for a Memory Hook Plugin become invalid when you connect/disconnect USB devices?
    And do you know a solution for this?
    Here's what I did:
    I determined some pointers for Radial-G via Cheat Engine and built a plugin with these pointers. Then I installed the plugin into SimTools.
    Result: Game Engine, Game Dash and Game Vibe showed the expected values.
    I did all this with just an XBox controller connected to my PC.
    Then I turned on my USB hub, which has all my simulator components connected: Thrustmaster HOTAS Warthog, MFG Crosswind rudder pedals, 3 SaberTooth 2x32, Razer Tartarus.
    I restarted the SimTools components as well as the game, and this time none of the SimTools components showed any values.
    I retested again with turned-off USB hub, and everything worked again.
    Now I went back into Cheat Engine and did a pointer scan with turned-on USB hub.
    Result: None of the pointers that I previously found with turned-off USB hub are still valid when the hub is powered.
    I made exactly the same experience some time ago when I tried to build a plugin for Lunar Lander.
    Do you have any hints for me?
  2. KydDynoMyte
    RTP, NC
    50Coins
    Are you finding thumbstick values and not telemetry data? Or just not static pointers?
  3. MarkusB
    4,213Coins
    I don‘t find stable pointers. Either they work with or without powered USB hub, but none of the found pointers work for both configurations.
