Question mdbox amc nano issue need help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jacominus10, Mar 28, 2020.
  1. Jacominus10
    Jacominus10 New Member
    - 88Coins
    4DOF
    It actually functioned properly until i unplugged all of the cables, and had some cable management. When I replaced all the cables except the usb, i turn on the power, everything seems alright. However, if I connect the control box with usb to pc, actuator will do some strange movements(goes up and down), it lost control. Is there something broken on the controller board? Can anybody help me?
    video link :
    https://sendvid.com/xc4av8hg
  2. Jacominus10
    - 88Coins
    4DOF
    edited : It actually functioned properly until i unplugged all of the cables, and had some cable management. When I replaced all the cables except the usb, i turn on the power, everything seems alright. However, if I connect the control box with usb to pc, and turn on the power again, actuator will do some strange movements(goes up and down), it lost control. Is there something broken on the controller board? Can anybody help me?
  3. Floris-Jan Eduard Lip
    Floris-Jan Eduard Lip Build4Power Racing
    The netherlands
    - 233Coins
    4DOF
    how long and what quality is the usb cable you're using? we had alot of usb related issues, now we use a 50cm one and everythng is rock solid
    154,388Coins
    +11,179 / 57 / -2
    If it started after bundling cables together then keep USB cables separate from power cords, clip on Ferrite Magnets on electrical and USB cables can help reduce electrical interference.
    Also try swapping out the USB cables, and if that does not help then try different USB ports.
