1. Hundreds of coffees, endless nights of debugging and coding, and countless feedback by our beta testers led to this new major release. SimTools 2.4 is probably the version with the most upgrades and improvements in a single release ever. Look at everything Dustin has included:
    SimTools 2.4 all features.
    Buy Download Package Now!
  4. We have a few rules which you need to read and accept before posting anything here! Following these rules will keep the forum clean and your stay pleasant here. Do not following these rules will lead to permanent exclusion from this website: Read the forum rules.
looking for advice on mounting the timing pulley (for linear actuator)
Discussion in 'DIY Motion Simulator Projects' started by hannibal, May 30, 2019.
  1. hannibal
    hannibal Active Member
    2,169Coins
    i can not for the life of me find anything ideal for my actuator, when it comes to mounting the timing pulley and the potentiometer.
    i am not keen on the 3d printed parts, especially looking at sixdegreesofflight's build, i feel like in time, the 3d parts will be subjected to wear, since the shaft rides on the 3d printed part, instead of on a bearing....
    i like to find a bearing housing for a bearing that has a 6.35mm bore, im also looking for a part number for a bearing with 6.35mm bore.
    at this time im just trying to affix a GT2 Timing Pulley 40 teeth Bore 6.35mm to a pot (or hall sensor)
    any suggestions appreciated :)
  2. OZHEAT
    OZHEAT Member
    Australia
    1,800Coins
    3DOF, DC motor
    Plenty of 6.35 id bearing exist.
    Search for " bearing 1/4" id ".
  3. hannibal
    2,169Coins
    bearings exist, how ever only one bearing assembly / block looks remotely feasible.
    searching miniature bearing block yield one descent result, and that option is not easy for me to affix to my actuator without more precision holes
    i came here to see if anyone had better ideas..
    only found this https://www.sparkfun.com/products/12333 , may use this or just develop something from scratch
