Question JRK not showing in utility config
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jstone, Jun 5, 2019.
Tags:
  1. Jstone
    Jstone New Member
    82Coins
    HI all, I recently have swapped over from MM to JRKs due to MM's power limitations. I understood how the MM functioned along with its software but I'm pretty clueless with these JRKs.
    I didn't install the drivers before plugging in my JRK which I realised was wrong but apparently, on Polulu's website the JRK should still work, its name just would be USB Serial Device. On my JRK utility configuration software, the JRK doesn't appear in the drop menu. I uninstalled and reinstalled the JRK drivers which didn't solve the problem. I tried manually updating the JRK drivers through device manager by selecting the driver subfolder within the Polulu folder but windows still insist that the best drivers are installed. I tried uninstalling the device then plug it back it with the Polulu drivers installed on my pc but that didn't work as well.
    What should I be doing to get my JRK to appear because I am unsure what to do. :think
    154,750Coins
    +11,196 / 57 / -2
    Have you tried uninstalling the drivers, rebooting, then install the drivers and finally plugin the JRKs.
  3. Jstone
    Jstone New Member
    82Coins
    Thanks for your reply Noorbeast,
    I tried following the steps you just gave me and I still have no success. My process went as follows:
    I went into device manager, uninstalled the JRK (2 USB Serial Devices in the COM ports, and the JRK in the Universal serial bus dropdown menu), after uninstalling these 3 I proceeded to uninstall the Polulu JRK folder and it's information through the JRK setup.exe, after doing so I restarted my computer. I then reinstalled the JRK drivers and it's information through the setup.exe and then restarted my computer again. After this, I finally plugged in the JRK and it came up the same in device manager as it did in the beginning and still won't show up in the JRK configuration utility.
    I may be doing something wrong with installing/uninstalling the drivers but I'm just not sure what I'm doing wrong.
    154,750Coins
    +11,196 / 57 / -2
    You could try downloading the Pololu utility and drivers again, just in case they are corrupted in some was, and try on a different computer, but I would suggest you just contact Pololu direct, as that sounds very odd and I have not struck that issue with any JRKs.
  5. Jstone
    Jstone New Member
    82Coins
    Okay! I solved it. I feel so stupid....
    So the problem I was running into was the drivers I downloaded, since I have the JRK G2's they use different software and drivers to the older 12v12, which was the link on Eaorobbie's post aswell as the first page google suggests when googling for the drivers. Now that I have the correct drivers installed the JRK's appear in the GUI and properly show up in my device manager.
    Whole lotta stress over nothing I guess, still thanks for your help Noorbeast, always super helpful for me. :cheers
