Question jrk not being recognized by windows 10
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jimbraj, Sep 13, 2017.
  1. jimbraj
    jimbraj New Member
    NJ
    116Coins
    I have a seat mover rig and I'm trying to add traction loss. I have everything hooked up and at first the jrk wouldn't connect to windows (only the 2 for the seat movers would) So I bypassed the hub that I'm using in my case and ran a new wire to the computer from the jrk. Now I am getting a green light on the board but I keep getting a windows error. it says that its not recognized and it shows up in device panel as unkown usb device descriptor request failed.
    am I missing something / is my jrk shot.
    thanks
    150,686Coins
    +11,018 / 55 / -2
    It could be faulty, a bad solder job or faulty USB cable.
    Check the usb cage is not loose, check your soldering and swap out the usb cable for one known to work on the other JRKs. If that fails contact the supplier.
  3. jimbraj
    jimbraj New Member
    NJ
    116Coins
    I will check the solder tomorrow. The cage feels solid. I also have another wire I can try.
    Thanks @noorbeast
    150,686Coins
    +11,018 / 55 / -2
    The cage can look solid but still be an issue, I had one JRK like that, so it pays to check:
