Question Is there anyone who play VR games without motion cancellation?
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Youngsoo Cho, Jun 25, 2018.
  1. Youngsoo Cho
    Youngsoo Cho VR Sim Racing Gamer
    Business Man
    Korea
    467Coins
    I am using oculus rift but it is very hard to set motion cancellation for me.
    is there anyone who play vr racing game without motion cancellation?
    if there is, kindly let me know how you play. Thanks
    154,750Coins
    +11,196 / 57 / -2
    You can get away without motion cancellation on a motion sim with small axis movements, motion cancellation is needed when there are large axis movements like a 6DOF rig.
    The other option is you can mount a Rift camera on the rig. High end vibration can affect tracking but for moderate motion it should be fine.
  3. Youngsoo Cho
    Business Man
    Korea
    467Coins
    Hello, I tried it before but couldn't play at all because it keeps recentering height. I also tried to disable positional tracking but there was drifting issue :(
    Thanks for the answer though.
  4. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    I play without it, camera fixed to the chair, no probs whatsoever. Since I have 3 cameras for roomscale, I just switch off the hub with other two, when play in motion. Don't know if this works for Vive, but Oculus is fine.
    154,750Coins
    +11,196 / 57 / -2
    Just to be clear for the benefit of others, as I had to stop someone from doing it, you can't mount a Vive Base Station on a motion rig, it is not a camera, rather it is multiple lasers with moving high speed precision parts and it will be damaged if shaken about. For the Vive use motion cancellation.
  6. Deadlock
    Deadlock New Member
    145Coins
    2DOF, DC motor, Arduino, SimforceGT, Motion platform
    I have the same drift issue when mounted on chair.oculus rift
  7. stevemontuno
    stevemontuno Active Member
    1,461Coins
    I don't use motion cancellation and have never had any problems with my rift cv1 with my 2dof seat mover,,,i have 2 camera's mounted high up on the wall & everything runs smooth as butter ,,,, was quite a relief after the first time i set it up..
    Although when i was using the dk2 i had the cam mounted on the rig and did get the odd glitch with violent seat movements,,not enough to put me off though..
  8. SEHATanguy
    SEHATanguy Member
    Belgium
    96Coins
    The same for me, I have a 3Dof and I tried the motion cancellation for the first time yesterday, it’s fine for me but it’s not like a must have, I forgot to mention, I use a mn Oculus
  9. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    I have 2dof seat mover with Oculus, wall mounted sensors, no motion cancell, works perfect
  10. Raredog
    Raredog Active Member
    Denmark
    25Coins
    2DOF, JRK
    I'm running a 2 DOF seatmover with a Vive, no problems at all.
  11. hannibal
    hannibal Active Member
    4,492Coins
    i wish i had my motion rig setup, to determine if i should get vive pro in order to implement motion cancellation.
    i plan to setup a 3DoF (yaw pitch roll) rig.. it is stationary, but it could rotate 360 in the yaw axis..
    anyone thinks motion cancellation is necessary?
    @Youngsoo Cho how many DoF is your setup?
  12. Youngsoo Cho
    Business Man
    Korea
    467Coins
    3dof with tracktion loss.
