irFFB
Discussion in 'iRacing' started by Twisted, May 30, 2019.
  1. Twisted
    Twisted New Member
    - 5Coins
    I was thinking , i play already a couple of years Iracing.
    Now there are several tools available, and i switched for the FFB to irFFB
    So it have several features to run different settings
    one of those is this:
    Use 360 Hz telemetry for suspension effects in direct modes
    • Only applies to direct modes
    • If checked the (unfiltered) 360 Hz suspension telemetry is used. This allows you to mix in some of the higher frequency detail that's absent from the 60 Hz output
    • If unchecked the 60 Hz suspension telemetry is used and the output is passed through the same FIR filter as the standard FFB. High frequency details will be absent but the latency of the effects will be lower
    Now iam really interested if this would work/change/improve the motion with Simtools?
    I still wait for my 2 DOF, so been busy reading up things.
