Hydraulic Actuators ?
Discussion in 'Motor actuators and drivers' started by Gadget999, Nov 8, 2017.
  1. Gadget999
    11,947Coins
    I have not seen any DIY rigs with Hydraulics
    is there a reason for this ?
    i have 6 Hydraulic actuators with linear potentiometers - they came off a flight simulator :)
    can i use simtools/SMC to activate them ?
    I am assuming the hydraulic actuators can be driven at different rates like a motor
    or are they switched digitally on and off up / down ?
    anyone got any hydraulic experience
  2. RandomCoder
    Control Engineer
    1,674Coins
    Hydraulics adds a level of complication and mess not normally found in DIY Sims. To use hydraulic actuators will require a powerpack and possibly a small accumulator. Each actuator will require it's own valve and depending on what you're planning it might be tidier to mount all these to a small manifold.
    If hydraulics is your area of expertise then I'm sure there's nothing stopping it from being used. But for most folk a low voltage 12V or 24V is a far simpler option.
  3. ruba
    ruba Member
    Engineer
    Krasnoyarsk
    5Coins
    2DOF, 3DOF, Arduino
    I found wery interesting pneumatic project on Youtube.
    I think pneumatic & hudraulic have much common in the construction.
  4. Ashraf
    Ashraf Member
    1,034Coins
    Arduino Mega 2560
    + ultrasonic HC-SR04
    + H-Bridge L298N
    + PWM speed control by proportional valve 12VDC
