How to setup actuators to allow me to keep casters
Discussion in 'Motor actuators and drivers' started by Globespy, Jun 18, 2020.
  1. Globespy
    Globespy Member
    656Coins
    Hello!
    Just about to install the 3DOF actuator kit I received today.
    Base is a Sim-Labs P1 extrusion rig.
    Currently on small but very strong industrial casters that lift the rig about 2" off the ground and make moving it possible.
    Actuators are 150mm stroke (or 6") and was wondering if it would be possible to mount them in a way that they were barely off the floor when they were in 'off mode', until they were initialized and then would lift the rig up off the ground.
    I'm guessing you can set the minimum and maximum stroke distance, so even if I'm losing say 2" of motion range, that would be worth it to me to be able to relocate the rig on the casters as it's going to be nearly impossible to move otherwise.
    Hope that makes sense and appreciate any responses.
    Thanks!
    153,065Coins
    +11,117 / 56 / -2
  3. Globespy
    Globespy Member
    656Coins
    Thanks noorbeast.
    I plan on 1 actuator mounted in the middle at the front of the rig and then one on each side just behind the seat.
    That's a very cool idea, but not something I'm in a position to attempt!
    I guess I will try to mount the actuators so they are barely off the ground until they are turned on, which will have a similar effect, but sacrifice some motion.
    Or I could just screw the casters back on if I need to move it and then it should be a simple job of quickly removing the actuators until I move it.
    Could not believe how heavy the box from PT was....over 100lbs, and add that to the 200lb of my rig.
  4. Globespy
    Globespy Member
    656Coins
    So I just unboxed the actuators and these things are HUGE, as in tall.
    There's no way in hell I would be able to do what I'm thinking as the casters would need to be close to a foot tall!
    My rig is going to be much higher than I thought, about a full foot higher even with the actuators in fully closed position.
    I have been looking at too many D-Box rigs, those are so small in comparison to these things.
    The wife hasn't seen these yet, I was thinking I could 'stealth mode' them, but Holy moly.....
  5. Trigen
    Trigen Active Member
    2,892Coins
    I have the P1x I was thinking about doing something similar but im going with a very simple solution. Just create a table with 3-4x caster that you put under when its not in use. I just grabbed some 3x the size of the Simlab ones when i came across them but its easy enough to just add a wooden spacer if need be.
    It goes like this:
    Start the actuators. they will lift. Move the caster table under and stop it so it lowers. Move it around.
