Resolved How to delete plugin?
Discussion in 'SimTools Pro & Entertainment Version' started by Tummie555, Jun 18, 2017.
  1. Tummie555
    Tummie555 New Member
    - 27Coins
    Sorry for the stupid question, but I went kinda impulsive with the pluginupdater and installed too many. How do I remove a "game" from the manager or do I need to reinstall everything?
  2. yobuddy
    51,664Coins
    You can remove them from this path when SimTools is shut down.
    "C:\Users\(your user folder)\AppData\Local\SimTools\GamePlugins"
    (AppData is a hidden folder btw)
  3. Tummie555
    - 27Coins
    Thanks for the quick reply!
  4. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Guys, I tried to remove some plugins this way, but now the GameManager crashes when starting. Seems to be an index problem, Putting the dlls back into the plugin folder solves the crash.
    Any idea what todo ?
  5. Dirty
    All the way up front.
    7,975Coins
    I have a somewhat related issue:
    When I install a plugin it shows up in C:\Users\<YourName>\AppData\Local\SimTools\GamePlugins :) However, I cannot update it to a newer version. When I drag a new plugin .zip onto the Plugin Updater I get a message that is was "installed successfully", but the .dll in C:\Users\<YourName>\AppData\Local\SimTools\GamePlugins is still the old one.
    Deleting the .dll manually works fine and allows new .dlls to be installed. Not sure if I am doing something wrong here, but so far I would recommend deleting the plugin.dll from that folder before installing a new version.
    Cheers, Dirty :)
