Question How can i solve mdbox espee error?
Discussion in 'Motor actuators and drivers' started by Jacominus10, Oct 8, 2020.
  1. Jacominus10
    Jacominus10 New Member
    - 88Coins
    4DOF
  2. Thanos
    Electronics Engineer
    United States
    2,917Coins
  3. Jacominus10
    - 88Coins
    4DOF
    Hi thanos. I have checked all of the encoder cables, and has tighten up the cables to the socket, still cannot figure out which one is loose .
    I also exchanged the cables of two actuator(one calibrates and one cannot calibrates), the testing result is still the problem actuator cannot calibrate.....Felt frustrated. Is there any possible method for me to check which cable has a problem? Thank you for your help.
  4. Thanos
    United States
    2,917Coins
    Maybe that actuator is mechanically blocked? Can you push or pull its rod with your hand? It takes a bit force, but you should be able to.
  5. Jacominus10
    - 88Coins
    4DOF
  6. Jacominus10
    - 88Coins
    4DOF
    Today i tried to reattached the rod, push it to the lowest position, twisted it few times. And then i turned on the power, testing axis at simtools, no error is found now, problem seems to be solved now! Thank you for your help thanos!
