How can I adjust the seat zero position with SimTools ?
Discussion in 'SimTools DIY Version' started by vsp19, Nov 25, 2016.
  1. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    Hello
    or
    How can I set or change the offset of the seat using SimTools ?
    My Motion-System: 2-Dof (SCN6) and SIMEXPIRENCE 4000Box
    153,065Coins
    +11,117 / 56 / -2
  3. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    This entry applies to J12RK
    But I have SCN6 !
    How do I change the zero position of the seat with the SCN6 ?
    153,065Coins
    +11,117 / 56 / -2
    Not sure with an SCN, @nclabs may know.
    You need to put your support request posts in the commercial sim thread, not the general DIY threads, @Historiker can assist in shifting it there.
  5. BlazinH
    16,677Coins
    To my knowledge there is not a way to do this with Simtools 1.3 so you must make a mechanical adjustment. However, again to my knowledge, I believe from what @yobuddy has stated recently that you will be able to with Simtools 2.0 by simply adding an offset value directly into the output interface.
  6. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    thanks for this information
    When will SimTools 2.0 appear ?
    and what improvements it will have compared to 1.3 ?
  7. yobuddy
    51,383Coins
    Zeroing a sim out needs to be done in hardware.
    Somewhere I explained it a bit better but in short, zeroing it in software makes for uneven movements.
    One side will have more movement or since one side can't move as far, the opposite side now need to move less.
    It just makes a lot more sense to just make the adjustments to the rig itself.
  8. BlazinH
    16,677Coins
    Hi @yobuddy. While I mostly agree with your assessment, sometimes you just need to move a seat or platform just a little bit to make it feel how you want it to when in its centered position. But from what you said in another thread, I figured if we can do math now in the output interface string, then to do an offset all that's needed is to add or subtract from the axis output you want to adjust. No?
  9. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Thanks for the answers and explanations
    This is very helpful for me.
    Too bad you can not change the seat offset by SimTools software.
    In SimComander that goes !
    Because in a Formula vehicle I sit differently like in a Rallyecar
  10. yobuddy
    51,383Coins
    Here is a link to my old centering post.
    https://www.xsimulator.net/communit...ion-software-simtools.4872/page-10#post-96360
    and what I posted, so you don't have to jump back and forth...
    Basically comes down to getting the most from your simulator.
    @BlazinH,
    Yes, It could be added to a Axis Assignment (math) plugin, or even an interface plugin I suppose.
    Pretty much anything is possible with the SimTools 2.0 plugin system.
  11. nclabs
    196Coins
    Just like youbuddy said, it's a lot better to "center" the seat in real life, using the auto centering feature the software does. In this way you don't waste any stroke, and you don't force the software to do strange things.
