Question Hoverboard motors for 2DOF motion simulator idea. How to drive and connect to SimTools?
Discussion in 'SimTools compatible interfaces' started by Ronan Design, Jun 8, 2021.
  1. Ronan Design
    Toronto, Canada
    1,666Coins
    I'm a noob and I'm looking toward building a simple 2DOF motion simulator for VR/MSFS. I can get a broken hoverboard with 2 good 36V hub motors. I'd like to try to use them for 2DOF rig and see how they do. But it seems you can't drive them with the usual drivers. I found a driver that works fine with hoverboard motors according to YouTube. And it's controllable by Arduino. My question is, can it work with SMC3? How can I interface it with Simtools then?
    I'm guessing that if Simtools can feed the PWM this board wants (see second picture), and I can rig a separate sensor/encoder that is normally used it can be connected to SMC3/Arduino. Maybe it would even be possible to use built-in hall sensors? Probably not...
    Any thoughts/advice? Thanks.
  2. workfayer
    workfayer New Member
    Brazil
    89Coins
    2DOF, 3DOF, Arduino
    Hello, how is everything? i had this same idea and i also found this bldc controller on aliexpress did you manage to find something if it is possible to make this combination of hoverboard bldc with simtools?
  3. Ronan Design
    Toronto, Canada
    1,666Coins
    No, I bought 2 PGSAW motors for my build.
  4. workfayer
    Brazil
    89Coins
    2DOF, 3DOF, Arduino
    I saw a project here using brushless motors in linear actuators, the controller used was the odrive the same could work with the hoverboard motors if someone help with the code, my idea is to build a simulator rotate 360º in roll and ywal like these motors it has a lot of torque I believe that with a reduction box they would be able to perform this turn.
