Help with MMOS and encoder
Discussion in 'DIY peripherals' started by RoryB, Aug 2, 2020.
  1. RoryB
    RoryB New Member
    61Coins
    Hello Everyone,
    I got the idea from this post with files from this post
    I have purchased a STM32F407VG and have managed to load the hex file to the board (image hyperlinked here)
    The only difference I can see between the board in the image and mine is that in the top right it says MB997D instead of MB997C in the image
    I dont know if i need to put the board into a application mode by moving pins or something, but it is connecting to mmos
    I have connected a 600 pulse per revolution (this one) to PA0 and PA1 and am running it with 5 volts.
    [​IMG] (image link)
    [​IMG] (image Link)
    You can't see the encoder as it is screwed into my wheel base.
    I have verified that the encoder works using a arduino pro micro (leonardo) but it wont work on the STM32 with the MMOS code.
    I haven't got any force feedback hardware setup currently as i wanted to verify that the encoder works. but it doesn't.
    Does anyone have any suggestions as to what could be the issue and/or any solutions.
  2. Nikiss999
    Nikiss999 Member
    418Coins
    DC motor, AC motor
    Do you have an encoder that needs pullup resistors?
    You can check that if you connect a multimeter between ground and cable (disconect it from disco beforehand).
    If the voltage is ~2 to 3 V when turning the encoder then you've got one that should work with the mmos, if you've got like 0.1 V then you need pullup resistors.
  3. Chris_Beeves
    2,183Coins
    Also, the STM’s input level is 3.3V right? Don’t know if pa0&1 are 5V tolerant.
  4. RoryB
    RoryB New Member
    61Coins
    I fixed it with 330 ohm resistors. Thank you so much!!!
  5. RoryB
    RoryB New Member
    61Coins
    I used 3v for the pullup instead of the 5v for the other bits of the encoder to not blow the pins on the board
  6. Nikiss999
    Nikiss999 Member
    418Coins
    DC motor, AC motor
    Nice!
    Encoder pins are 5V tolerant but since you already made it work it doesn't matter anymore :)
